5v source
Old Nov 4, 2008 | 09:40 PM
Truckshop's Avatar
let me know what sensor you want to splice into and i can tell you what color wire and pin #. on the map and the tp i believe the gray wire is the 5v reference.
Old Nov 4, 2008 | 09:44 PM
PSM's Avatar
PSM
probably the map sensor ill try the gray
Old Nov 4, 2008 | 09:47 PM
Truckshop's Avatar
thats it. the black wire is the ground.
Old Nov 8, 2008 | 07:24 PM
PSM's Avatar
PSM
Would splicing in and putting those two sensors off the gm 5v mess up the signal. I dunno if the added load of two more sensors would make the pcm not be able to keep that voltage at 5
Old Nov 8, 2008 | 07:41 PM
Truckshop's Avatar
it should be fine. if you are worried here is a link to a 5v power supply.
http://www.aeroforcetech.com/sensor.html
Old Nov 9, 2008 | 02:36 AM
PSM's Avatar
PSM
Pn the map sensor i have grey, orange, and green.. any idea which one of those is ground. I'd test the truck, but its still not close to being back together yet
Old Nov 9, 2008 | 07:27 AM
sprayed8's Avatar
I'm pretty sure the green is the wire that varies because that is the one i tapped into on my TPS for WOT nitrous activation, so i don't think that's the one you want.
Old Nov 9, 2008 | 08:07 AM
Truckshop's Avatar
the orange is the low reference (ground) that comes from the ecm. in the harness i would pick one of the black ground wires and use it.
Old Nov 9, 2008 | 09:49 AM
PSM's Avatar
PSM
wouldn't I want to use the same ground wire the sensors use since that is what the ecu is using as reference to give 5v off of?
Old Nov 9, 2008 | 09:52 AM
Wilde Racing's Avatar
How do I change this text
I believe that 03's don't have EGR, I thought that they did away with it in 02...at least on the 1500's...
Yep, But I'm pretty sure you can still use the pin from the pcm ...
