50lb injectors?
Old Jun 30, 2006 | 09:35 AM
Default 50lb injectors?
thinkin bout gettin em for my 6.0 im swappin in, any insight on these? good bad? also it says i need to pigtail, what does that mean exactly?
Old Jun 30, 2006 | 10:07 AM
Lord Aries's Avatar
I was getting ready to ask a similar question of if i need to change out from my 42# Marine Injectors to something bigger... I figure i probably need the 50#er's at the very least, oh well one more thing to add to the list of parts needed for the 404...
Old Jun 30, 2006 | 10:33 AM
Superado's Avatar
11 Second Truck Club
I believe that the plug-ins are different, need to use adapters or splice-in pigtails.
May even have to use stand-offs on fuel rails as well if they're taller
Old Jun 30, 2006 | 12:42 PM
Zick's Avatar
Wht so big, turbo or S/C?
My 31lbs work just fine for what I have.
Old Jun 30, 2006 | 01:38 PM
Lord Aries's Avatar
Turbo... 15-20lbs of boost...
Old Jun 30, 2006 | 02:00 PM
Zick's Avatar
I actually was referring the question to GMracer. I can see what you have in your sig, but he doesn't list anything.
Old Jun 30, 2006 | 02:53 PM
Lord Aries's Avatar
HAHA opps... Guess i am more bored at work then I thought... LoL
Old Jun 30, 2006 | 04:14 PM
i plan on FI i want 11s and i have decided if im doin the magna or sts or livernoise. depends on money i guess, and i saw these in the forsale so i figured id ask but im just gonna do the marine 8.1
Old Jun 30, 2006 | 07:49 PM
An injector connector with the two wires would be a pigtail. You'll have to get the car type - look like these:
Here is the link:
Summit
The larger injectors are 5/8" longer and you will need the same length spacers to raise up your rails, along with adding the same length to the bolts that strap the fuel rails down. You can get 1/4" galvanized pipe from Home Depot and cut to length for spacers.
Old Jul 1, 2006 | 08:03 AM
Scott Mills's Avatar
I am going to be selling my marine 42's soon. I am at the limits of the injectors.
