50 state Long Tubes
Old Aug 29, 2010 | 11:03 PM
wentbig's Avatar
Default 50 state Long Tubes
Who sells 50 state LT headers. I like the ARH with duel cats can I use them in Ca. ? Wat is a Y-pipe? why don't you just run duels? I have to get my restriction down.
Old Aug 29, 2010 | 11:11 PM
BuyAmericanIron's Avatar
Unfortunately, nobody makes 50 state (or any state legal) long tube headers. To meet current regulations, the catalytic converter has to be as close to the engine as possible, so it will "light" quickly upon startup. Most are mounted within inches, if not bolted directly to the exhaust manifolds. Your only choice is to buy a set with the converters if you are concerned about the environment, and then have your vehicle tuned to run properly and without a check engine light on.
Old Aug 30, 2010 | 01:05 PM
RibeiroBJJ's Avatar
Praise The Lowered
As stated above there are no carb aproved long tubes..I run them and pass smog fine..they are coated & s/s so they hold heat in well..
-Your only other options are Bassani mid-lengths which retain your factory cats ..you have to cut and weld a small section before the cats though..TOG headers were also good and mid-length, but they are out of buisness..
Old Aug 30, 2010 | 01:44 PM
cali92rs's Avatar
Here is a post where I asked the same thing...
https://www.performancetrucks.net/fo...d.php?t=466800
Ribeiro, just curious, is the setup you mentioned in the other thread what you're running (pacesetters/ORY)?
Thanks
Old Aug 30, 2010 | 02:03 PM
RibeiroBJJ's Avatar
Praise The Lowered
Thanks
No, I am running Arizona speed & Marine stainless long tubes that are ceramic coated, with 2 1/2" Magnaflow spun cats..kinda wish I would have just used oem cats..which are 2 1/2" and probably work better...But it passed with a 212/216 cam
Old Aug 30, 2010 | 02:23 PM
cali92rs's Avatar
Cool, thanks.
I have heard the samething elsewhere, that hi-flow cats don't flow enough more than the stockers to justify the $$$.
Old Sep 1, 2010 | 12:53 AM
Fill's Avatar
Where were you able to find someone to smog it with those? Im in S.D. too and I researched for months and nobody would touch it with LTs with no CARB #. I finally gave up and registered my truck at my buddies address up in Campo.
AHelm3
Apr 8, 2016 07:51 AM
2500ZL1
Jan 25, 2016 06:30 AM
Ken in AZ
Sep 17, 2015 07:08 AM
Martin4_8
Aug 13, 2015 07:31 PM
Suburban2500
Jul 13, 2015 09:57 AM
