5.7 LS1 and Whipple??
Old Apr 22, 2003 | 10:46 AM
ranwalk's Avatar
Default 5.7 LS1 and Whipple??
Just kicking around an idea.To broke to actually do it <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> If you were to put in an LS1 engine,would a Whipple charger work??Bolt up??Just curious if it would be able mount up the same or if there would be a good bit of fabrication needed to do it.I know these engines really turn some good hp numbers with a centrifical charger....wonder how they would resond to a twin screw style like a Whipple??
Randy <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Apr 22, 2003 | 01:05 PM
Ryan23silverado's Avatar
Default Re: 5.7 LS1 and Whipple??
I checked all of this stuff out last night. Yes it will work, but with minor modification to the LS1 water pump. There is a bracket that holds the SC that screws into the water pump in one location right next to the thermostat. On truck water pumps this is already drilled and tapped. It is not drilled and tapped on the LS1 pump, but there is casting there to do it - this would be an EASY task. Other than that, you would need the holes in the passenger head to mount the other bracket, and it is drilled and tapped on the LS1/6 heads already.
Oh yeah, you would have to run electric fans also for radiator hose clearance. The water neck on the LS1 exits the front of the pump, as the truck one is on top. Unless you modified the water neck, you would run into probs. with the hose hitting the belt or the clutch fan.
Just another idea: Magnacharger already has a roots kit that fits onto the 'Vette LS1. It would work in our trucks too. But, if you already have the Whipple, fabrications are one easy to drill bolt hole in the H2O pump and electric fans.
Old Apr 22, 2003 | 07:03 PM
hohl's Avatar
What would be involved converting the original Whipple two belt system to the new one belt system?
Anyone know where I can find pictures of the two different installations?
Old Apr 23, 2003 | 11:27 AM
11 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan23silverado:
<strong> I checked all of this stuff out last night. Yes it will work, but with minor modification to the LS1 water pump. There is a bracket that holds the SC that screws into the water pump in one location right next to the thermostat. On truck water pumps this is already drilled and tapped. It is not drilled and tapped on the LS1 pump, but there is casting there to do it - this would be an EASY task. Other than that, you would need the holes in the passenger head to mount the other bracket, and it is drilled and tapped on the LS1/6 heads already.
Just another idea: Magnacharger already has a roots kit that fits onto the 'Vette LS1. It would work in our trucks too. But, if you already have the Whipple, fabrications are one easy to drill bolt hole in the H2O pump and electric fans. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you swap in an LS1, just use all of the truck accessories. Any SC available for the trucks will bolt right up. You will not be able to run as much boost, so you would have to order a different pully.
Lthompson
Oct 2, 2015 12:45 AM
Dawas
Sep 20, 2015 12:00 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
FormulaZR
Sep 14, 2015 05:23 PM
