5.7 l31 tuning a stock setup
Old Mar 3, 2015 | 09:24 PM
mkn57rar's Avatar
Registered User
Question 5.7 l31 tuning a stock setup
im looking to add some power cheap and i am thinking that i should start with a tune.
i plan on replaceing the spider injection with the new version off a later model.
cat back and somewhere down the line i will cam it but what i am wondering is
what kind of improvements can i expect from a pcm4less mail in tune? right now it just has a 140 amp alternator fixed issue of dimming lights on the high end of WOT. k&n air filter Bosch iridium plugs and some kind of performance wires.
I know i sound very newbish but i am doing alot of research before i decide to go in to modding.
also what cam can i run without yanking the heads.
Old Mar 4, 2015 | 02:46 PM
97ChevyVortec's Avatar
I've heard they are good, can also check out black bear performance.. say the real power is upgrade to the 0411pcm then you can have full tune ability... I will be in the process very soon on updating the spider injection along with the vmaxx intake spacer, Cam and long tubes plus a black bear tune probably
Old Mar 7, 2015 | 12:51 PM
Skip Fix's Avatar
The Jet/Tuner Cat system allows some tuning capacity support is minimal,but the 411 computer is evidently faster as well as more easily tuneable with any LS motor style program.
Old Mar 13, 2015 | 09:24 PM
mkn57rar's Avatar
Registered User
So do you know what max cam lift and duration I can run?
Old Mar 13, 2015 | 09:25 PM
mkn57rar's Avatar
Registered User
Default max cam
Old Mar 15, 2015 | 09:47 AM
Fast355's Avatar
I have had good luck running the F/Y-car LT1 cams and the stock Lt4 cam in these engines. I would change the valvesprings on a higher mileage engine regardless of the cam. If you went with an Alex spring/retainer set I would have a hard time not running Lunati's version of the LT4 Hotcam. The Barebones 276/286 grind.
Go5.3tt06
Sep 12, 2015 09:29 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
grantpo
Jul 15, 2015 12:21 PM
4B11T
Jul 13, 2015 03:48 PM
