5.3L vs. 6.0L Throttle Body
Old Dec 19, 2005 | 12:41 AM
02gmcwaldoch's Avatar
Default 5.3L vs. 6.0L Throttle Body
I was digging around in the LS1 Tech forum and they were saying that the 6.0L LQ4 Throttle Body is 80mm. Is this larger than the stock 5.3L LM7 throttle body? By how much??
Old Dec 19, 2005 | 02:14 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Same size. Same tb I promise I have 3 different tbs sittin in a buddies garage all of them are the same one from a 5.3 off my original engine and two from 6Ls and they re the same.
Old Dec 19, 2005 | 07:51 AM
ktmrider's Avatar
I have been told there is a difference with the LQ9 TB ( 80mm ) and the 4.8/5.3/LQ4 TB ( 75mm ). Never measured it myself tho....
Old Dec 19, 2005 | 07:57 AM
SSlow 4.8's Avatar
nah, their all the same size... i have a few laying around as well.
Old Dec 19, 2005 | 08:08 AM
ok...thanks for clearing it up!! I should have discovered this forum earlier...You guys are awesome!
Jesse
Old Dec 19, 2005 | 10:12 AM
6.0caddy's Avatar
the LQ9 at least out of the denali i pulled out is a electronic, not mechanical
Old Dec 19, 2005 | 10:54 AM
SS_bnoon_SS's Avatar
Same with my '03 SS TB, electrical. It's a change that was made from '02 on all gen III iirc, though I might be off a year...
Old Dec 19, 2005 | 05:17 PM
1slow01Z71's Avatar
Yes the actual tb size is the same 03+ have drive by wire tbs that use an electrical motor instead of the cable to actuate the butterfly.
Old Dec 19, 2005 | 09:54 PM
Onyx 02's Avatar
Will a drive by wire TB work on a cable driven setup. I have a 2000 Z-71, cable-driven, that I want to upgrade to a drive-by-wire. What will I need to do this swap? My 2002 already came with the drive-by-wire, cause of the traction assist.
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
smokeshow
Aug 23, 2015 08:23 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
