5.3L TB swap or mod
Old May 19, 2008 | 10:17 PM
LMSeven's Avatar
Originally Posted by thunder550
The 4.8/5.3/6.0 throttle bodies are all the same.
All of the V8 truck intake manifolds and throttle bodies for a given year engine are the exact same.
All of the 4.8/5.3/6.0 intake manifolds and throttle bodies are the exact same.
Old May 19, 2008 | 10:55 PM
1989k1500's Avatar
But would I get any gains from putting on the bigger 6.0 tb?
Old May 20, 2008 | 12:27 AM
00ChevyScott's Avatar
Wearin' da big hat
only if you add a throttle body spacer.
Old May 20, 2008 | 10:21 AM
BlueSS's Avatar
and drill some holes in it for some spray... lol
Old May 21, 2008 | 12:40 PM
SS_bnoon_SS's Avatar
Originally Posted by Mack201
Thanks for the responses.
I just want to make sure as my 5.3L I measured at 72mm and not 78mm.
If the 6.0L is truly 78mm it is a 15% increase in size and I can shop the local junk yards for around $50
Beats spending $300+ on an aftermarket 80mm TB
I think your measured the casting at the back of the TB bore, correct? If you look at it again, you will see that the back side of the throttle body knecks down about 5-6mm behind the blade, which would equal your measurement of 72mm vs. the actual blade/bore diameter of 78mm.
Search on here for ported stock throttle body or words like that and you will find several hits. I posted pics in sort of a how to format if you search for throttle body and my user name.
Old May 21, 2008 | 02:50 PM
Mack201's Avatar
yes I measured the back as that is the smallest opening and therefore the area of the greatest air restriction.
Thanks for the information.
Everyone is referring to these stock TB's as 75mm or 78mm and I find that misleading as the smallest opening at the rear is 72mm.
Thanks, I have noted the part # appears to be the same for the 4.8/5.3/6.0 so it appears that they are all the same bore.
I quess the next obvious question is will I see any difference in performance if I go to a modified TB such as 80mm and change nothing else?
The reason I ask is because my 2003 is a drive by wire.
If the stock TB that is used is large enough for the 6.0L motor, it is certainly more than enough for the 5.3L
I assume because it is drive by wire, the TB will only open up to what the engine can match for the proper Air/Fuel mixture.
That being said, it would seem pointless to use a larger TB unless I also purchased a tuner to take full advantage of the extra CFM's available.
If a larger TB is used and a tuner is then used to modify the settings, will the stock injectors be sufficient or do they need to be upgraded also?
Is my thinking correct on this?
LIFE WAS SO MUCH EASIER WITH MECHANICAL TB'S
Old May 21, 2008 | 10:39 PM
1989k1500's Avatar
I believe the tb will open to whatever the pedal tells it to.
Old May 22, 2008 | 01:31 PM
Gains of 7-8 HP is pretty typical with a properly ported TB on LS1's, though I've never seen anyone dyno it on a DBW truck. Most people note improved throttle response and I've seen about 7% in MPG. A ported stock TB will net more flow area than an aftermarket 80mm TB and cost you a LOT less.
To answer your question, your DBW TB works just like a cable TB does. Mat it and the TB is wide open.
The stock injectors are good with a few bolt ons, but are sized a little small for much more than that. Ported TB will not put you over the edge.
Old May 23, 2008 | 05:45 AM
Mack201's Avatar
Thanks, I am on the hunt for a ported TB.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chevyl33
Aug 24, 2015 08:21 AM
Ketis
Jul 23, 2015 12:37 PM
lxcoupe
Jul 14, 2015 10:14 PM
ALynch
Jul 6, 2015 09:49 AM
