5.3L TB swap or mod
Old May 19, 2008 | 06:51 PM
Mack201's Avatar
Default 5.3L TB swap or mod
Has anyone here checked into using a TB from a vortec 6.0L in your vortec 5.3L ?
I have changed the TB on my 2.5L jeep to the TB from a 4.0L jeep with good results as the 4.0L TB was 10mm larger and the same bolt pattern. All I had to do was change over my original AIS motor to get the correct idle and open up the manifold to match the opening of the larger TB
My 2003 vortec 5.3L TB is 72mm and I see aftermarket TB at 80mm but I cannot find any information on a stock 6.0L TB
I do not want to spend $300-$500 on an aftermarket TB if I can have similar results with a junk yard vortec 6.0L TB for $50.
If the 6.0L TB is has the same venturi opening as my 5.3L TB, would grinding the lip from the back of my stock 5.3L TB make any difference?
Old May 19, 2008 | 06:52 PM
thunder550's Avatar
High on diesel fumes
The 4.8/5.3/6.0 throttle bodies are all the same.
Old May 19, 2008 | 08:29 PM
Mack201's Avatar
I have spent a good part of the day trying to research this and this is what I have found.
4.8/5.3/6.0 share the same bolt pattern but appear to have some differences
The 4.8L is either 70mm or 72mm venturi, may use an air deflector, and may use a throttle stop prevents the blade from opening up more than 85% like the 4.3L TB does.
My 5.3L uses a 72mm venturi, no sign of a deflector, no idea if blade opens 100% as it is drive by wire
The 6.0L may use a 78mm venturi, deflector doubtful, no idea if blade opens 100% on the drive by wire
Can anyone confirm?
If so, then it would appear that they are not all the same even though they are mechanically interchangeable.
Old May 19, 2008 | 08:35 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Like Thunder above answered, the 4.8/5.3/6.0L throttle bodies are generally accepted as 78mm and interchangeable. The 4.3L may be different.
Old May 19, 2008 | 08:54 PM
Mack201's Avatar
Thanks for the responses.
I just want to make sure as my 5.3L I measured at 72mm and not 78mm.
If the 6.0L is truly 78mm it is a 15% increase in size and I can shop the local junk yards for around $50
Beats spending $300+ on an aftermarket 80mm TB
Old May 19, 2008 | 09:50 PM
snwmn984's Avatar
go measure a 6.0 tb.that should give you the answer your looking for.
Old May 19, 2008 | 09:51 PM
thunder550's Avatar
All of the V8 truck intake manifolds and throttle bodies for a given year engine are the exact same.
Old May 19, 2008 | 09:54 PM
Mack201's Avatar
If I had a 6.0L TB I would measure it but I do not.
I was hoping that someone here may have one or has measures one in the past.
Old May 19, 2008 | 10:04 PM
thunder550's Avatar
All of the 4.8/5.3/6.0 intake manifolds and throttle bodies are the exact same. There are two throttle bodies for these trucks. Cable, and drive by wire. You will find absolutely no difference between them besides that.
kbracing96's Avatar
Dude, they are all the same. I don't know where you found your information, but it is flawed, they are ALL 78mm, both the drive by wire and the cable TB on the 4.8/5.3/6.0.
