5.3l ls6 cam or no cam
Old Apr 3, 2010 | 11:13 AM
4.6 eatin gm's's Avatar
Originally Posted by mvrotc
How about reliability wise is it gonna start shattering springs and valves?
And how bout the pushrods can i use the stock ones ?
not if u install it right. i have had this setup in my truck for a year now and had now issues. 04 zo6 cam,home ported heads,yellow springs, 7.425 pushrods,cai,borla muffler,zo6 maf and has run strong chirping 2nd gear and reving it to 6500 numerous times. its basically a stock part so there shouldnt be any problems if u install it right.
Old Apr 3, 2010 | 12:05 PM
mvrotc's Avatar
still havent gotten an answer
from searching alot of ppl say they use stock pushrods others say that u need hardened
Old Apr 3, 2010 | 12:25 PM
budhayes3's Avatar
PT's Slowest Truck
I'm not sure if the stock pushrods will be the right length as the LS6 cam has a smaller base circle. I have read of guys using the stockers with that cam with no problems though...
Old Apr 3, 2010 | 12:29 PM
mvrotc's Avatar
does anyone know for sure cuz i dont wanna make a mistake
Old Apr 3, 2010 | 12:54 PM
1BAD_LS1 Tunes's Avatar
FormerVendor
if you have stock heads you need to run 7.425 pushorods as the basecircle of the ls6 cam is smaller, although there are several guys who run the stock 7.4 rods without issues.
I run 7.425 pushrods..... remember the RIGHT way to select a pushrod is to buy a pushrod length checker and measure for your exact needed pushrod length!!!!! You can buy them for around $20.
Old Apr 3, 2010 | 02:42 PM
mvrotc's Avatar
So what i want to know is im hearing 7.4 ie the stock pushrods that are in the 5.3l are just fine....
Is this true lol
Old Apr 5, 2010 | 12:57 AM
cory 5.3's Avatar
yes you can use stock pushrods i have a Ls6 cam in my 5.3 truck for over a year its a great cam of the money and the power all u really need are the Ls6 springs im running 4.10 and it still gets around 17.5 mpg and drive it every day
Old Apr 5, 2010 | 10:51 AM
FERGHOE's Avatar
I have a LS6 cam in my 5.3 with stock pushrods and springs and it runs like a beast..
Old Jul 14, 2010 | 08:57 AM
chrisfrost's Avatar
Default 5.3l 7.4 push rods ? Not in my 5.3's neighborhood
Hello fellow motor pushrod heads , my pushrod is longer than you're pushrod ! he he , I could'nt resist . Ok down to business . I just purchased a LS6 cam I believe from a 2004 vette . supposedly has .525 in/ex lift . So I decided to wait until cam gets here before fig/deciding and obtaining pushrods for it . So while waiting I grabbed 1 of the 5.3 pushrods and measure it . It's 7.325" . So I'm thinking 7.4 or 7.425" push rods is a big difference . So when You use the terminology "stock length" push rod please make sure You specify what engine that "stock length" push rod is 4 . I was kinda hoping 2 get an answer also 4 what length p rod I would need 4 my swap , but reading a couple of these posts , I've realised/decided to wait and figure it out 4 myself, the safest way I know. So , 1 more bit of info hopefully some of You can take advantage of is "Fred Beans parts" has LS6 yellow springs new 4 $59.00 complete set plus shipping .
Good luck all .
darnie
Aug 10, 2015 10:25 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Aboss
Jul 9, 2015 10:28 AM
