5.3L knock sensor?
Old Jul 20, 2007 | 09:43 AM
kbracing96's Avatar
You should be able to reuse the intake gasket, as long as you don't damage them. You shouldn't need to drain the coolant (there is no coolant passages in the intake), you will have to disconnect the to small coolant lines on the TB, but you can just stick some 3/8 bolts in them to plug them. Any sensor safe RTV will be fine and only needs to be used to seal around the rubber seals for the knock sensors so water can't get down in them.
lucas287
31
Jan 12, 2021 06:18 AM
zblee
Nov 11, 2015 12:41 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Pimpinpete
Sep 8, 2015 07:39 PM
