5.3 ?'s
Old Jun 25, 2002 | 12:38 AM
Default 5.3 ?'s
Does any company make rods, and piston kits for the 5.3... Do any of these companies offer a stroker kit for the 5.3
________
******* Latin
Old Jun 25, 2002 | 12:44 AM
BigTex's Avatar
Default Re: 5.3 ?'s
Crank and rods will interchange with the LS1. Finding pistons will be difficult.
Old Jun 25, 2002 | 10:59 AM
Default Re: 5.3 ?'s
Big Tex the crank will not interchange with the ls1. Did research at my local GM dealer and a couple of after market suppliers. Eagle makes the rods, and the pistons have to be made special through JE at a cost of 800.00
________
Healthy living advice
Old Jun 25, 2002 | 11:12 AM
GREGGO's Avatar
Default Re: 5.3 ?'s
The 5.3 and the 5.7 have the same crank, why would they not interchange? The shops I have talked with say that anyway.
Old Jun 25, 2002 | 11:25 AM
Default Re: 5.3 ?'s
Sheeet, i don't know other than what they have told me. I hope they will cause then it will be easy to build a stroker kit for the truck.
________
Lsd rehab dicussion
Old Jun 25, 2002 | 04:27 PM
LM7/LQ4's Avatar
Default Re: 5.3 ?'s
I am not 100% sure but I think the balancing is the only difference between all the cranks except 4.8's.
Old Jun 25, 2002 | 04:34 PM
LM7/LQ4's Avatar
Default Re: 5.3 ?'s
Also some of the 6.0 cranks 99 mostly were made just a little bit longer (about 3/8's) to bolt to the 4L80E transmission. 2000 GM used a shorter crank with a spacer.
Old Jun 25, 2002 | 04:50 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: 5.3 ?'s
I've heard that the 5.3L cylinder bores can be bored quite a bit but, they are small to begin with.....I think. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
You should be able to get it to 6.0L with just changing to the LS1 crank and boring it.
John
Old Jun 25, 2002 | 05:16 PM
LM7/LQ4's Avatar
Default Re: 5.3 ?'s
5.3 and 4.8's use the same block which can be bored only 0.030. That with a 3.622 stroke which is the same as a 5.7 LS1 would make a 330ci. 6.0 364.
Old Jun 25, 2002 | 05:25 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: 5.3 ?'s
I'm just going from what I've seen. Here is a thread where a guy has a 5.3L block bored .125+ over. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> It was done by ARE.
https://ls1tech.com/ubb/cgi-bin/ulti...=002594#000005
Hyde you may want to talk to MTI, ARE, or one of the other competent engine shops to see what they say about the bore. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
