5.3 ?'s
Old Oct 29, 2004 | 08:52 AM
Default 5.3 ?'s
I have a 1993 C-1500 with a 4.3. i want to put a 5.3 out of a truck in it. I was wondering if any one knows what i will have to do to my cross memeber or oil pan to make it fit.
I was also wondering what was the max psi that engine can handle with stock internals. I want to run a custom twin turbo set up.
I have heard that LS-1's and 5.3's are almost identical. is that true. if so what all will match up.
Thanks
Severed Ties
Old Oct 29, 2004 | 09:22 AM
Thanks
Severed Ties
hey,
the turbos i got for 85 each off of a little dodge coupe that i think was pushing around 9psi on one turbo.
thanks
Old Oct 29, 2004 | 09:29 AM
FILE's Avatar
Why not go get a 6.0 since you are already doing a swap.
Old Oct 29, 2004 | 09:35 AM
Well. It is easier for me to get a 5.3 for less, and i really dont know how much room i will have to run the turbo set up. i will post a diagram of my set up as soon as possible.
That is a good idea though. I will look into it. I hadnt really given a 6.0 that much thought.
thanks
Old Oct 29, 2004 | 10:11 AM
a 6.0 has the same dimensions as the 5.3 I believe. Just go for the 6.0 and you should enjoy it alot more. plus you will have the extra cubes which is always good.
Old Oct 29, 2004 | 10:22 AM
FILE's Avatar
Yeah the 6.0 has the same dimension as the 4.8/5.3. Even if you get the 6.0 for $1,000 more, it is still very well worth the extra hp and torque.
Old Oct 29, 2004 | 03:06 PM
A 6.0 wont be that much more it is just harder for me to get ahold of. i have access to wrecked vehicles, so a complete system will only cost me about 2g's, tranny and all. maybe i will go with that.
Any tips on the turbo or the actual swap?
thanks
Old Oct 29, 2004 | 03:53 PM
hey,
thanks
I doubt that would be good for anything other then a <2.5L
It's not about how much PSI you can make, it's about how much CFM you can move. And I think that puny turbo is best served for 4cyl and motorcycles
Old Nov 2, 2004 | 08:45 AM
hey is there a way to make the turbos flow more cfm's, like making the wastegate larger.
thanks
anybody know the cost of a banks turbo system for this?
Old Nov 2, 2004 | 07:35 PM
qwank's Avatar
i'd get and LS1 or an LS6 instead of a 6.0L cuz they weigh less.
