5.3 pushrod length
Old Sep 25, 2005 | 12:22 PM
98TAauto's Avatar
Default 5.3 pushrod length
im just curious but a friend installed a 216/224 114 cam i believe in his 01 5.3. He said someone told him to put 7.3 pushrods in instead of the 7.4's to make the valvetrain geometry correct? I thought if anything he would need longer rods since the cam base circle is smaller?
heads and everything else is stock btw.. just a cam/spring/pushrod swap.
if he did put the 7.3's in, what side affects would he cause compared to the 7.4's?
Old Sep 25, 2005 | 12:36 PM
bluecajun5.3's Avatar
11 Second Truck Club
i don't know about the 7.3's. when i did my cam swap all i did was change the springs and pushrods. went with the manley chrome moly pushrods 7.4's stock length and torqued the rockers down to 22ftlbs.
Old Sep 25, 2005 | 12:38 PM
budhayes3's Avatar
PT's Slowest Truck
7.3 sounds too short to me, I agree that with the smaller cam base circle, he'd want to go slightly longer if anything. Comp recommended their 7.4's for my 206/212 cam, and I know in my heart that if I got a pushrod length checker I could probably go a little longer and quiet down my valvetrain some. You'd think that too short a pushrod would allow for excessive vavletrain clearance...I'd bet that the lifters would be jumping off the cam lobes.
Old Sep 25, 2005 | 02:04 PM
samdogmx's Avatar
8 Second Club
i used some 7.4s with mine, i've heard of some guys using 7.35s but not 7.3s
btw i have a set of thunder racing 7.4s for sale if your intrested
Old Sep 25, 2005 | 02:50 PM
98TAauto's Avatar
thanks for the info everyone.... he found out that he needed 7.4's instead so all is good to go now
Old Sep 25, 2005 | 04:36 PM
02sierraz71_5.3's Avatar
for proper preload he is gonna need a hair longer than 7.4, what is the difference in the base circle between the aftermarket cam and the stock one? Account for the difference with a longer pushrod, it will sound like a tiny diesel with the stock rod size if he has allready done it youll hear what Im talking about.
Old Sep 25, 2005 | 05:03 PM
99Silver6.0's Avatar
Not 7.3 thats way too short. Pushrod length on a 5.3 with an AM cam should realistically be 7.425 or 7.43.
thompson
31
Oct 20, 2015 03:42 PM
outlawz2004
Sep 19, 2015 08:12 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
nickpc82
Aug 30, 2015 09:18 PM
GM1697
Jul 14, 2015 01:21 PM
