5.3 mod info
Old May 21, 2006 | 10:51 AM
Quik's Avatar
5 year bitches!
Originally Posted by Soon2bSpooled
ok well that makes sense, he just said he wanted to be in 13's so i was going more aggressive so he'd be there faster, fasteddie, yes do your research
you do know that a cam like i said the cheater has shown numbers in the 400s to the wheels and its off idle cam
now im useing this for reference i dont recomend it for his application
99-CHEATR-CAM Thunder Racing Custom "CheaTR" Camshaft - 214/230 .601/.578 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam. $389.99 Buy Wish
Old May 21, 2006 | 11:05 AM
no i didnt know this but its a good cam i agree....i have never reasearched it so i know next to nothing other than the numbers it shows
Old May 21, 2006 | 11:18 AM
fasteddie94's Avatar
11 Second Club
Of course. I am just trying to find a decent starting point to work from. I didn't with my LT1 and now I have countless cash tied up in it. Trying to avoid that. Just curious about how much work it takes to get a tank like mine running with stock L's.
How do the rears hold up in these trucks?
How about the transmissions?
What is the TB converter you guys are mentioning?
Old May 21, 2006 | 11:25 AM
trail blazer stall, eventually expect to get your trans built, some sooner than later. rears hold up good but you will need a lower ratio 4.10ish or something. it will hold up
Old May 21, 2006 | 11:28 AM
Bad_Apple's Avatar
I would say...
Custom Tune
4:10's
CAI
E-Fans
Fuddle 3000 stall
Trans-Go Shift kit & Servo's
Pacesetter L/T's (no cats)
Comp 918 springs
ASP Pulley's
That should get you easily a mid-high 13 and still have very good DD manners.....
Old May 21, 2006 | 09:56 PM
the cheater cam also requires dual springs and titanium retainers which would bump up the cost...why does that cam require the dual springs? i think it would be cool to get a custom grind along the same general parameters that the "cheaTR" but on a set up that could use comp 918's
Old May 22, 2006 | 05:15 PM
Quik's Avatar
5 year bitches!
those springs arent that much actually, almost same as 918s dpending on who makes the set
Old May 22, 2006 | 10:33 PM
yea but you have to buy the retainers and ID locaters too which adds another 200 bucks
i was just wondering why you had to have the dual set up cuz i wanna know if an FMS custom 216/228 .58x 114/5/6 would require the dual set up
RoidedSS
Aug 11, 2015 11:51 AM
JordanH
Aug 8, 2015 07:59 PM
Sexyrado327
Aug 2, 2015 04:08 PM
gtyler04
Jul 28, 2015 06:21 PM
bk_cauley
Jul 19, 2015 09:56 PM
