5.3 & Ls1 Intake
Originally Posted by Yelo
I know I'm gonna recieve a half-dozen PM for responding to this (YES...I WILL TAKE pictures guys....someday...but it's gonna wait until the heads/cam swap so I can do the WHOLE write-up at once), but the LS1 intake swap is REALLY easy......you can use all of the stock truck accessories, ALL you need to do is modify the water-pump neck where it sticks up off of the water-pump (cut it down to 3/4" tall) and buy the idler-pulley adapter form Speartech ($70), the stock injectors and rails will work (use spacers....I figured it out.....so can you) and so will the stock crossover tube (looks dumb...but it works, if the asthetics offend you custom bend one)
Originally Posted by 2003blue5.7
Dont hold your breath waiting on Yelo to take pictures I've been waiting for several moths....
seriously.....my GF uses the truck for work during the day, and when she gets home I go to work, most weekends the LAST thing on my mind is taking pictures of my intake
when I do the heads/cam swap I'm gonna do the WHOLE write-up at once (we've never had one of those...i thought it might be a good thing)
Originally Posted by 2002yroneformula
The intakes tested were the 6.0 truck, LS1, LS6, and the new FAST LSX if I'm not mistaken.
With a stock cam, there really wasn't a clear winner. Once a cam was added to the mix, things changed a little. The truck intake is still quite a strong piece, and I can't see changing it unless you're hardcore or need the underhood clearance.
https://ls1tech.com/forums/showthrea...HP+intake+test
The last time they did the test with the stock motor and switched the intakes to see the results now they switched out 3 cams with each intake...
All dynoed withthe motor out of the car.
Comp Cam
xr265hr...0.522/0.529 inch intake exhaust, 212deg intake/218deg exhaust, 114deg lob displacement
Truck intake= HP/TQ, 429/422 @5900/5000rpms
LS1 intake= HP/TQ, 450/439 @5900/5000rpms
LS6 intake= HP/TQ, 459/447 @5800/5000rpms
FAST intake= HP/TQ, 462/450 @5900/5000rpms
Comp Cam
xr275hr...0.566/0.568 inch intake exhaust, 222deg intake/224deg exhaust, 112deg lob displacement
Truck intake= HP/TQ, 468/445 @6300/5200rpms
LS1 intake= HP/TQ, 462/442 @6300/5000rpms
LS6 intake= HP/TQ, 471/449 @6300/5000rpms
FAST intake= HP/TQ, 479/452 @6400/4900rpms
Comp Cam
xer281hr...0.595/0.598 inch intake exhaust, 232deg intake/234deg exhaust, 112deg lob displacement
Truck intake= HP/TQ, 486/447 @6500/5000rpms
LS1 intake= HP/TQ, 484/445 @6500/5000rpms
LS6 intake= HP/TQ, 495/448 @6500/5000rpms
FAST intake= HP/TQ, 503/452 @6400/5000rpms
Comp Cam
Comp Cam
Comp Cam
HectorM52
Aug 18, 2015 12:40 PM
05GMC4.8
Aug 7, 2015 09:55 PM
