5.3 into 65 pcikup
Old Aug 4, 2011 | 05:59 PM
ZONES89RS's Avatar
In-Zane Moderator
Default 5.3 into 65 pcikup
Well, this will be carbed, it is a 2002 5.3, th350 with a 3000 converter, i was thinking a 220/224 grind, but i only found one with a 114, i want a 110, but a 112 will work better than the 114.
Should be 3.42 gearing, probably stick with manifolds for now, otherwise, a Vic Jr is what we might go with, but a Performer RPM will probably get the go since it will keep torque up higher down low and mid range.
Any suggestions on the cam specs? The owner wants a lope but still tow a boat and those specs to me should make him happy.
Old Aug 12, 2011 | 11:44 PM
Leevon's Avatar
Kind of sounds like my build, a 2002 5.3L carbed in a '50 chevy pickup with 3.42 gears, TH350 and 3000 stall. I used the comp cams 212/218 on 114 lsa cam with TSP pushrods and LS6 yellow springs. Haven't fired it yet.
Old Aug 14, 2011 | 01:28 PM
ZONES89RS's Avatar
In-Zane Moderator
That 114 will be great for a EFI build, are you going injected or no?
maxspeed05V
Sep 23, 2015 10:48 AM
nickrench3
Sep 17, 2015 08:48 AM
OVOAustin
Sep 15, 2015 08:32 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
