5.3 into a 383 stroker???
Old May 27, 2010 | 08:17 AM
ChevyTruck's Avatar
something else
Default 5.3 into a 383 stroker???
Has any one done it?? It's some thing that has been crossing my mind quite a bit.
Old May 27, 2010 | 09:52 AM
Mangled03gmc's Avatar
Baltimore Whore
Don't think you can take a 5.3 that big.. Will be to much out of the the cylinder walls. A 5.7 block yes.. I think
Old May 27, 2010 | 09:56 AM
LsxCody's Avatar
Yes it can be done. A guy over on ls1truck has a build thread.
Old May 27, 2010 | 09:57 AM
smokeshow's Avatar
Mod with training wheels
Walls do get real thin though..
Old May 27, 2010 | 10:00 AM
LsxCody's Avatar
You have to use a 4" crank. Cylinder walls shouldn't be a problem.
Old May 27, 2010 | 10:11 AM
ChevyTruck's Avatar
something else
Can you post a link of it?
I have come across a brand new block for CHEAP, that is why I am asking.
Old May 27, 2010 | 10:13 AM
Baltimore Whore
This is possible on some blocks. Not all are created equal(im serious) If this is the route you decide to go, make sure you get the block checked for cylinder thickness, esp at the bottom.. Plus this is going to be more then building a reg enegine J, having to get a stroked crank.. What hell are you smoking up there in the D yo
Old May 27, 2010 | 10:16 AM
00ChevyScott's Avatar
Wearin' da big hat
I wouldn't even bother honestly. Why do that when you can spend the same money on a 6.0 and have a much bigger motor.
Old May 27, 2010 | 10:24 AM
LsxCody's Avatar
i would go for it, do something different.
heres the link http://www.ls1truck.com/forums/lsx-t...-build-up.html
Old May 28, 2010 | 09:11 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Isnt a 6.0 less cubes then a 383?.....Unless your reffering to stroking a 6.0
