5.3 intake replaced woth ls1 intake
Old Feb 11, 2004 | 04:52 PM
bigdsracin's Avatar
Default 5.3 intake replaced woth ls1 intake
i am currently lookin into installing my 5.3 in a mazda rx7. one problem, the intake is way to tall. i recently had someone suggest putting a ls1 intake on it. my question is, will all my existing compnents bolt to the ls1 intake off my 5.3 intake? such as injectors, fuel rail throttle body ect.
when this all does bolt together i beleive it will fly.
5.3 into turbo350 into 390 gears with ind suspension with only 2600 lbs. numbers are lookin good
Old Feb 11, 2004 | 04:59 PM
Flyer's Avatar
The LS1 intake is a lot shorter than the truck intakes. The water pump on the trucks is a lot different than the one on the cars because of the lower intake design. The throttle body on the car intake will hit the water neck.
You could change out water pumps, but all the rest of the belt accesories would have to be changed as well.
You might talk to www.smcperformance.com about some belt accesories, he usually has some relatively low mile take off's for sell at a fair price.
Old Feb 11, 2004 | 05:05 PM
Yelo's Avatar
contact John at SpearTech, He makes a $70 bracket that will allow the use of the truck waterpump and accessories with the LS1 intake....you still have to cut down the water neck on the pump but the LS1 manifold WILL fit after the neck is cut and a 90* rubber hose is put in it's place (it's REALLY close...like 1/16" close...but it DOES fit)
Old Feb 11, 2004 | 06:29 PM
bigdsracin's Avatar
thank you for the quick responses ill look in the water pump problem. with that intake everything off the 5.3 will bolt to it such as the throttle body?
Old Feb 9, 2005 | 04:25 PM
BlackSilver's Avatar
what about the alternator bracket? wont that hit the tb?
i'm asking b/c i have a lingenfelter intake that i'm seriously considering installing.
(you need e-fans for this to work in a truck too for clearance issues)
Old Feb 9, 2005 | 07:14 PM
ITLstallion04's Avatar
A buddy of mine has a '99 SS with a 383 stroker, he used the ligenfelter intake and said it put off so much damn heat, so he switched back to a stock type plastic one. Tell me how you like it.
Old Feb 9, 2005 | 07:18 PM
XLR8NSS's Avatar
Adkoonerstrator
The idler wheel on the alt bracket gets moved and the bracket needs to be cut off for TB clearance.
Old Feb 10, 2005 | 03:25 PM
it gets moved where?
Old Feb 10, 2005 | 04:48 PM
XLR8NSS's Avatar
Adkoonerstrator
It gets moved down under the alternator. Speartech makes a special mount to relocate it that uses the three existing bracket bolts.
Old Feb 10, 2005 | 04:49 PM
so then i'll need 97 vette fuel rails too?
