5.3 heads?
Old Dec 24, 2013 | 08:30 PM
loganauld's Avatar
Registered User
Default 5.3 heads?
Alright fellas what are good heads for a nice street build on a 5.3? I know stock heads are decent when ported but will they keep up with aftermarket heads? Any advice is appreciated
Old Dec 24, 2013 | 08:31 PM
Boosted_Silverado's Avatar
how much do you want to spend? what do you plan on doing besides heads?
Old Dec 24, 2013 | 08:35 PM
loganauld's Avatar
Registered User
Lets pretend money aint a factor because im trying to figure out what my options are and texas speed 228 cam maybe a bigger bore FAST fuel rails and green top 42lb injectors and lt headers and a 3k stall
Old Dec 30, 2013 | 04:46 PM
black01_WS6's Avatar
Are you ever going to have boost in your future? An aftermarket set of heads like Dart/AFR will offer a thicker deck that will be less likely to pass coolant.
If you are staying motor only, a good set of ported and polished 5.3 heads will flow what you need. I fit a 232/234 cam in with my LS6 stage 2.5 heads from Texas speed that are 59cc heads.
Texas speed usually has a good price point on a heads and cam package that will not break the bank and perform very well. Remember its all about the combo, not the most expensive parts you can throw on the motor.
Old Dec 30, 2013 | 11:25 PM
Whitecrewcab's Avatar
Lightly ported 5.3 heads with 2.00/1.57 valves, don't get a set that has the runners hogged out to 225cc. If money is no object, AFR 205's or TFS 215's. They use the small runners to keep the velocity up and have excellent ports and valves.
JordanH
Aug 8, 2015 07:59 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
06 4.8
Jul 15, 2015 07:17 PM
