5.3 forge pistons
Old May 30, 2009 | 03:43 AM
Chente's Avatar
Default 5.3 forge pistons
I am trying to find some flat top forge pistons for a 5.3 trying to prove a point that this little engine run strong I am currently running a 5.3 with low compression well 9.5 and running 13.0 to 13.3 on an off but cant pick up my dynamic compression due to the dish piston. thanks for any help cant go over 8.0dcr
the currently set up is a 220 224 112+2 on a 2005 truck fullbolt on mad 345 hp on a mustang dyno and 343 tq
thanks again
Old May 30, 2009 | 08:42 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
you can get L33 pistons which are flat top, not forged but then you might want to look for a set of 243 heads to keep compression in the 10:1 area, milled for a little higher CR.
Everyone here knows the little 5.3 rocks
Old May 30, 2009 | 08:48 AM
Derek @ EDO's Avatar
FormerVendor
Have you checked to see what Wiseco has to offer?
Old May 30, 2009 | 09:12 AM
Luke03's Avatar
x2
http://www.wiseco.com/Catalogs/Automotive/Chevrolet.pdf
page 13
Old May 30, 2009 | 12:59 PM
Chente's Avatar
thanks for the help guys got it I just have to check how much they are lol
Old May 31, 2009 | 11:18 AM
1FastBrick's Avatar
Custm2500's Rude Friend
just under $600, whish they were in production when I did mine.
Old May 31, 2009 | 11:33 AM
ZR1 DREAMING's Avatar
Look at Mahle or Wiseco for some forged slugs for your motor. Mahle's are pretty inexpensive if you end up boring it.
Personally I'd skip the 243s on a stock bore 5.3 if all you're after in higher compression.
Old May 31, 2009 | 12:13 PM
Cuerva's Avatar
11 Second Truck Club
Chente, You don't need forged pistons for your "Frankeinstein 50 shot" that drops you 1.3 sec's and takes you to 12.1, unless you plan on running your "Frankeinstein 100 shot" JFWY.
Old May 31, 2009 | 12:19 PM
1FastBrick's Avatar
FWIW, I beleive only weisco has a true off the shelf forged pistons for the 4.8/5.3 Bore.
Everyone else requires a custom order and the prices are almost double. How ever if they have finally steped up and do make an off the shelf piston, please do let us know.
Old May 31, 2009 | 01:26 PM
Mr. Sandog's Avatar
Bore that sucker out to 5.7 - your piston selection goes up exponentially, and no one's the wiser.
