5.3 Extremely low idle
Hey guys.... 2000 Tahoe 5.3. About 100k on the clock. Exhaust, intake, TB spacer I think. Extremely low idle.... like 300 or so RPM. Its supposed to be about 600-650 right? Any ideas what could cause this? I can correct it with EFI LIVE I beleive but I would rather fix the problem! Thanks
I've seen that before. Around 99-00 they had the recall, bulletin, whatever about the throttle sticking and it said to install a fixed orfice PCV valve and plug the hole in the throttle blade and reset minimum air. I don't know if all of the above got done minus setting minimum air or what but I have seen a handful of them idle stupidly low. To see what PCV valve you have just pull it out and see if its got a small hole in the center or a large hole with the little rattle valve inside. Also to see if the hole is plugged in the throttle blade just yank the intake tube off and see. Other then that I have no idea why they idle that low unless the IAC passage is plugged but that should cause some pretty bad drivability problems.
Cleaned my Airraid filter and the MAF. Still no dice.
I think its this POS throttle body spacer - was on it when I bought it. Can it be removed and use the same bolts to put it back together or what? Easy as unbolting and rebolting?
I've already pulled off the AEM, cleaned the TB, and now I'm down to drilling the flow hole a little bigger. I'm having the issue too. But it's only in the cold weather that this issue is more apparent.
Don't drill any holes Lisa, if cleaning the throttle body didn't help, the IAC valve is more than likely sticking or shot. You could try removing it off of the throttle body and cleaning it first, and if that doesn't work it would probably be worth a shot to just put a new IAC in.
*EDIT* just for poops and giggles, pull the hose off of the fuel pressure regulator located in the center of the driver's side fuel rail and make sure that no fuel drips out. I doubt that is your problem though as the extra fuel would actually be helpful on cold start ups during the winter...
Ok.. Looked that one up and it seems hardly intrusive. I think I can handle that one. And the part isn't that costly that it would suffocate me...
