5.3 engine
Old Aug 30, 2016 | 10:51 AM
Kodiak2314's Avatar
Default 5.3 engine
Does anyone know why part number 12457705 would work for 2001 gmc 5.3 it's calling for part number Chevrolet Performance 19301546 all I'm doing is installing a cam and valve springs one is new the other is reman and cost more?
Old Aug 30, 2016 | 10:54 AM
SLOPONY's Avatar
So you are looking at getting a new or reman engine just to pop in a cam and run it? Id get a low mileage take out from a wrecking yard for $250-$1000 and run the **** out of it, and buy a turbo kit with what you save...
Old Aug 30, 2016 | 10:58 AM
Kodiak2314's Avatar
I want new and I didn't want but about 30hp was going to add longtubes and tune! But can't figure out why that engine would work
Old Aug 30, 2016 | 11:07 AM
FFDP's Avatar
What's wrong with your engine now?
A cam upgrade and headers/tune is going to be alot more than just 30hp. Figure 50-70 if everything is done right.
Old Aug 30, 2016 | 11:11 AM
FFDP's Avatar
Seems like a complete waste of money to spend $2,300 or even $3,200+ on a factory stock long block.
You can buy a used engine and get the full machine work done for way way less than that cost of a new engine.
Old Aug 30, 2016 | 11:20 AM
Kodiak2314's Avatar
Less down time and I would rather have new
Old Aug 30, 2016 | 11:30 AM
FFDP's Avatar
Would be no downtime if you used your motor in the truck now but it's your wallet not mine.
Pick your posion then, any stock 5.3 block is fine. Either of those two engines you posted will accept a camshaft upgrade just like any other 5.3 out there.
Old Aug 30, 2016 | 11:34 AM
Kodiak2314's Avatar
Thanks you thing it would fit?
Old Aug 30, 2016 | 11:47 AM
FFDP's Avatar
What do you mean will it fit?
A 5.3 LM7 is a 5.3 LM7, what is going to be any different about it if you get the right year.
1999 enignes are different by a little bit because of the longer crank I believe.
And I just re-read the details about the 01+ engine, they have a core charge of $2,500!!!!!. After you factor that in the $200 in shipping back to them for your core you are talking $6,200 for just an engine before you get your core charge back.
$3,660 after the core charge, you could buy like 3 used engines and get a machine shop to make them brand new again for the same price. Holy man is that like getting raped with no lube.
Old Aug 30, 2016 | 12:21 PM
Kodiak2314's Avatar
Ok thanks so the 99 would work? And whould the different crank work?
