5.3 cam recommendations...
Old Mar 28, 2013 | 07:02 PM
fast84's Avatar
Default 5.3 cam recommendations...
For truck in sig. Want a decent motor cam but will also occasionally use nos and eventually turbo charge. Is there a cam that I could go with and later spray it and eventually turbo without changing cams again?
Thanks
Old Mar 28, 2013 | 07:16 PM
06murder's Avatar
. 224/230 114 great on spray don't know. Bout on fi
Old Mar 29, 2013 | 02:08 PM
fast84's Avatar
How do you think that cam would do on motor with the 34-3600 conv I have with 4.11's I have?
Old Mar 29, 2013 | 04:00 PM
myth's Avatar
You need to look into a custom grind.
Old Mar 29, 2013 | 05:15 PM
Beatdown Z's Avatar
Laid Back
The cam you want doesn't exist...
Old Mar 29, 2013 | 05:43 PM
06murder's Avatar
Would work good..but you want nos and boost cam its one or the other
Old Mar 29, 2013 | 05:54 PM
gamble686's Avatar
Depends on how serious you plan on getting with the spray and boost. Almost any decent cam will make more power than stock boosted or sprayed. I think something like a TR220, any isky cam, or a speed inc turbo cam would be fine. However, max effort you will need different cams for each build.
Old Mar 29, 2013 | 06:22 PM
turbo truck's Avatar
Ls6 cam is what's gonna work best for your 5.3 turbos like stock to mildly stock cams but the ls6 cam is the most affordable and plentiful cam you can get for a soon to be turbo truck
JordanH
Aug 8, 2015 07:59 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
