5.3 cam
Old Sep 5, 2022 | 05:53 PM
crumpat's Avatar
Registered User
Default 5.3 cam
Okay so I plan on installing a cam on a 5.3L LM7 gen 3. I have these on my lists. is everything right for my truck and enough to properly install it?
If I am missing something I need please be sure to let me know. Thank you
Stage 2 5.3 Truck Cam 212/218, .600"/.600" (112 LSA)
PAC 1219 Single Beehive Springs
Seals (150-900FK x8 & 150-901FK x8)
7.400" pushrods
Melling High Volume Oil Pump
Crank Bolt/Gasket Kit w/ ARP Bolt #28-CamGskKitARP
Old Sep 5, 2022 | 05:56 PM
FFDP's Avatar
You don't need a high volume pump, a standard replacement pump does more than enough for oil flow.
Old Sep 5, 2022 | 06:03 PM
crumpat's Avatar
Registered User
thanks! so everything listed will work on my truck?
Old Sep 5, 2022 | 06:39 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Missing cam plate. I would suggest doing lifters so pulling heads and doing head gaskets and everything that goes with that.
Don't have to I guess but it is recommended.
Old Sep 5, 2022 | 06:41 PM
FFDP's Avatar
Probably. I don't see headgaskets listed or water pump gaskets. You need a new camshaft retainer plate too because that comes with a new seal.
Old Sep 6, 2022 | 01:50 PM
swathdiver's Avatar
5 Year Member
Lotta cam and a lot of lift, did you have head work done?
Old Sep 6, 2022 | 05:44 PM
RedXray's Avatar
100% Redneck
BTR just came out with a new high lift cam for the 5.3 last week that will work with those PAC 1219 springs.
217/23X, .613/.607, 114 LSA
"The 5.3 Hot Rod cam is BTR's newest offering for the guys with 4.8 & 5.3 displacement truck engines. This cam delivers an aggressive idle while maintaining good street manners.
It makes slightly less torque down low than our Truck Norris cam yet produces an additional 20+ HP at peak. These newly designed BTR lobes were developed in house and tested on our Spintron and Engine Dyno to achieve the highest overall power curve while also maintaining our strict valvetrain stability and durability standards."
BTR 5.3 HOT ROD CAMSHAFT
Old Sep 6, 2022 | 07:07 PM
swathdiver's Avatar
5 Year Member
Still too big for a street truck IMO. To my way of thinking, there's not much to be gained going over .500 lift with stock heads so no need to strain or beef up the valve train, just doesn't seem to be enough profit in it.
bizle
Jan 17, 2020 05:04 PM
Velocity1
Sep 18, 2012 09:15 AM
chris99gmc
Jul 5, 2012 04:50 AM
SimpleManLance
Dec 1, 2008 03:30 PM
