5.3 to 6.0 swap, help.
Build the drivetrain to handle the extra cubes and ponies, a few guys have gotten by by bolting a 6.0 to their 60E, but most end up with a busted 60E
If you plan on bolting the 6.0 to your stock trans, start saving for a back up just in case. At the least do the mods to the trans that you can without getting too invasive such as a shift kit, servos, and a big cooler. After the trans I'd upgrade the rear diff to a detroit trutrac or eaton or auburn posi unit...as with the trans, guys have gotten by with the stocker (by driving like grandpa and having some luck), but the majority end up with broken parts. Hell, I smoked my 60E with my mildly modded 5.3, and shortly after swapping in an FLT Level7 my G80 took a dump...just can't wait to see what I break if I ever can afford to put my LQ9 together!
im thinkin bout swappin out the 5.3 to a 6.0. If anyone has done this could you help me out. And also what mods to do to the engine while ive got it out. Im wantin 400+. -99 silverado/5.3/Hypertech power programmer/k&n 77 series/heddman shorties/poweraid throttle body spacer
im with bud though.. dont forget about the expense of a trans when it grenades.. not if it grenades... WHEN IT GRENADES....
i had a shift kit in mine and it lasted about a year with the stock 6.0... i put the cam in and got a real tune.. and took the torque management out... and about a month later... BOOM (1-2 shift broke the output shaft) .. i was only putting down 364/374
Nimoryan
Jul 5, 2015 03:50 PM
