5.3 to 5.7
Old Jul 4, 2007 | 02:29 PM
  #21
Mark Johnson's Avatar
Well got some good news, fellas. I've found a rebuild kit for the 5.3 which allows overbores of .020", .030", and .040". Man I'm so stoked! BTW the name of the out fit is RPM machine, haven't found out where they are yet. Say- does anyone have a P/N# for an LS6 oil pump, I hear they're the best and LS6 valve springs; I understand that there are orange green and yellow LS6 springs- which ones whould I want and do any of them require any machining...............
Thanks- I always learn a truckload when I stop in here.........
Old Jul 4, 2007 | 02:44 PM
  #22
kbracing96's Avatar
Check with SDPC------->
You will want the yellow LS6 valve spring, about 60 bucks.
Old Jul 4, 2007 | 04:16 PM
  #23
That's a big 10-4, thanks......
Old Jul 5, 2007 | 10:45 AM
  #24
SS_bnoon_SS's Avatar
There's enough meat to rebuild the blocks with 5.7 overbore pistons too. For a standard bore 346, it's 99mm bore. Then you can overbore from there for future rebuilds with .010, .020, .030 5.7 piston rebuild kits.
What you have to weigh as options are: Does the 5.3 to 5.7 machine work and hardware cost more than a used LS1 5.7 block/hardware, and remember to include machine work for both ways since a used LS1 from the classifieds will most likely need a rebuild too.
Or why not throw in a stoker crank for a 383?
Old Jul 5, 2007 | 08:16 PM
  #25
skyhighsami's Avatar
no title here
I vote 6.0 or a built 5.7 I would love to have a LS1 block because then you would have the less weight but with my wheels it doesn't really matter.
Old Jul 5, 2007 | 08:22 PM
  #26
Phantom's Avatar
11 Second Club
Old Jul 5, 2007 | 08:52 PM
  #27
This is great- if there's enough meat in there to overbore still from 5.7(99mm)- I'm going 5.7 when the time comes, 'cause hey- who knows if the rest of the truck will still be around by the time I'd rebuild again.........
Old Jul 7, 2007 | 03:49 AM
  #28
99Silverado5.3's Avatar
Originally Posted by Ferocity02
I'm not blowing smoke up your ***. How about you go look for yourself. The search wasn't working, but here's one that was at the top of the list. All the parts for an LS1 shortblock for $470 before bargaining.
https://ls1tech.com/forums/showthread.php?t=744579
Old Jul 7, 2007 | 11:56 AM
  #29
Originally Posted by 99Silverado5.3
3 hun just for a block with a missing trans bolt hole? YUCK! It would cost another hundred to have someone weld on another trans ear unless you can do it yourself. Sure, you could probably get by without one trans ear, but only if you didn't build enough horsepower and hit it with nitrous like I plan to do.
Something I did find on car-part dot com were several 6.0L rebuildable core shortblocks for $300... They are getting cheaper by the minute it seems for the iron blocks, but the cheapest 5.7 was $900 and it was a damaged short block. Dang salvage yards still think those LS1's are made of gold or something.
Old Jul 7, 2007 | 12:09 PM
  #30
Well f me, thought I found a good deal.
6l lq4 block for 3?
If you could shoot me a pm with a link to the 6l block I would appreciate it
