5.3 to 5.7
#21
Well got some good news, fellas. I've found a rebuild kit for the 5.3 which allows overbores of .020", .030", and .040". Man I'm so stoked! BTW the name of the out fit is RPM machine, haven't found out where they are yet. Say- does anyone have a P/N# for an LS6 oil pump, I hear they're the best and LS6 valve springs; I understand that there are orange green and yellow LS6 springs- which ones whould I want and do any of them require any machining...............
Thanks- I always learn a truckload when I stop in here.........
#24
What you have to weigh as options are: Does the 5.3 to 5.7 machine work and hardware cost more than a used LS1 5.7 block/hardware, and remember to include machine work for both ways since a used LS1 from the classifieds will most likely need a rebuild too.
Or why not throw in a stoker crank for a 383?
#27
Originally Posted by SS_bnoon_SS
There's enough meat to rebuild the blocks with 5.7 overbore pistons too. For a standard bore 346, it's 99mm bore. Then you can overbore from there for future rebuilds with .010, .020, .030 5.7 piston rebuild kits.
This is great- if there's enough meat in there to overbore still from 5.7(99mm)- I'm going 5.7 when the time comes, 'cause hey- who knows if the rest of the truck will still be around by the time I'd rebuild again.........
#28
Originally Posted by Ferocity02
I'm not blowing smoke up your ***. How about you go look for yourself. The search wasn't working, but here's one that was at the top of the list. All the parts for an LS1 shortblock for $470 before bargaining.
#29
Originally Posted by 99Silverado5.3
It would cost another hundred to have someone weld on another trans ear unless you can do it yourself. Sure, you could probably get by without one trans ear, but only if you didn't build enough horsepower and hit it with nitrous like I plan to do.
Something I did find on car-part dot com were several 6.0L rebuildable core shortblocks for $300... They are getting cheaper by the minute it seems for the iron blocks, but the cheapest 5.7 was $900 and it was a damaged short block. Dang salvage yards still think those LS1's are made of gold or something.
