4WD switch
Old Nov 2, 2003 | 07:38 PM
KeukaZ71's Avatar
Default 4WD switch
sometimes my truck's 4 hi will work when i push the button. but most of the time it won't. auto 4 wd will work though. then it won't go back into 2hi. i have to hit 4hi and 2hi a bunch of times, then finally it will go back into 2hi. sometimes it has a mind of its own and automatically switched into 4lo. i have heard that these switches sometimes go bad. any other possibilities?
Old Nov 2, 2003 | 07:57 PM
z7199's Avatar
The buttons need to be recaled this is a very common problem Does the service 4WD message pop up? Well go to the dwealer and buy the buttons NEW they are about 40-50 dollars. You can try to take the buttons apart and spray them with electrical contact cleaner that helped mine.
Old Nov 3, 2003 | 08:57 AM
Big Mike's Avatar
My truck is 4 months old. I've been getting a "Service 4WD" message. When that message appears, the 4WD doesn't work. WTF?
Old Nov 3, 2003 | 05:05 PM
KeukaZ71's Avatar
once in a while the service 4wd light goes on. but not very often
Old Nov 3, 2003 | 06:15 PM
Jonathan@Thunder's Avatar
FormerVendor
Default 4wd switch
I had the same problem last week. I changed the switched and it works perfectly now. I had the service 4wd switch come on and go off for the past 3 months. The switches apparently go bad pretty often according to our GM guy.
Jonathan
Old Nov 3, 2003 | 09:27 PM
Big Mike's Avatar
Which switch needs to be changed? 2W, 4W high or 4W Low???
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Blklgt
Sep 28, 2015 03:21 PM
sTNT971
Sep 26, 2015 04:22 PM
