4L80E swap for the 4L60E?
Old May 3, 2003 | 06:50 PM
Hit Man X's Avatar
Default 4L80E swap for the 4L60E?
I was reading some old posts about this a while ago, and was wondering if anyone had gone through with this swap? If so, what all did it intail?
Thanks!
Old May 3, 2003 | 09:27 PM
LS1TECH Sponsor
Default Re: 4L80E swap for the 4L60E?
You would do this swap cause the 4L80 has more parasthetic power loss then a lighter duty 4L60?
Old May 4, 2003 | 06:29 PM
Hit Man X's Avatar
Huh? Can you clarify what you are trying to tell me...
A fully build 4L80E is good to 1200hp or so. A 4L60E is good to maybe 750hp. Big difference. Granted the 4L80E has a shitty 2.40:1 1st gear, a $600 low gear set gives you about a 2.78:1 1st gear which isn't too bad.
Old May 4, 2003 | 07:25 PM
LS1TECH Sponsor
What i'm saying is The 4L80E trans is bigger and would have a heavier rotating mass then a 4L60 trans. I'm sure a 4L80 trans can be built for 1200hp but who is gonna run that much power in a truck anyway. I don't know why you would wanna swap a heavy duty trans for a light duty trans unless it was for weight.
Old May 4, 2003 | 09:39 PM
Hit Man X's Avatar
I don't see how a fully race-prepped 4L60E will hold ported/polished heads, decent cam, and a MagnaCharger. You are talking well over 500rwhp maybe more.
I'd rather have a trans that can take the abuse and keep on running and not break. That way if I feel the need for more power (which I am sure I will) it will take it.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
