4L60E pan, how much fluid?
EFI | GEN I/GEN II/GEN III/GEN IV Engines |Small Block | Big Block |
Mar 13, 2003 | 03:49 PM
Ram4Pick
Feb 2002
Clyde, California
I was going to drain some fluid and replace it with fresh just to help between trans services. How much fluid does the pan hold?
Thanks, Jim
Ram4Pick
Find More Posts by Ram4Pick
Mar 13, 2003 | 07:40 PM
BigTex
Nov 2001
East of Dallas
Re: 4L60E pan, how much fluid?
I think I remember 4 quarts, but am not totally sure. With my new converter and almost empty transmission, I used 11 quarts total.
BigTex
Visit BigTex's homepage!
Find More Posts by BigTex
Mar 18, 2003 | 11:54 PM
chevybuff
Feb 2003
Blacksburg, VA
5 quarts in the pan, 11.2 from dry.
chevybuff
Find More Posts by chevybuff
4l80 swap, no reverse
Blwn99x
11:14 AM
Transgo or sonnax
Wolftrk99
Dec 3, 2015
08:12 PM
Whirring noise...normal or an issue?
lukn4trbl355
11:19 PM
01 c3 ecsb awd 6.0 turbo
turbo6c3
06:11 PM
Trick Turbo oil drain drill/ tap and pressure port drill/ tap + fittings
lxcoupe
12:36 PM
Tags
2002
2003
4l60
4l60e
ca
corvette
drain
drop
dry
fluid
gm
hold
pan
recommended
service
trans
Back to Subforum
View Next Unread
5.3 Ported and Polished heads
12:12 PM
