4l60E Failure due to Shift Solenoid?
Old Mar 17, 2005 | 06:54 PM
ridnlow's Avatar
Default 4l60E Failure due to Shift Solenoid?
Ive decided to let someone local rebuild my transmission and the guy that is doing it said that it failed because the shift solenoid went out? Has anyone else had this problem. My SES light never came on but when he scanned my computer it said that the shift solenoid had failed.. Would this actually cause a transmission to burn up?
Old Mar 17, 2005 | 06:58 PM
SSlow 4.8's Avatar
Which shift soleniod? Thought there was more than one when i went to do the shift kit.. or maybe that was more than one accumlator?!?!
Old Mar 17, 2005 | 07:07 PM
ridnlow's Avatar
Im not sure.. it would shift 1-2 but after that it would just rev...
Old Mar 18, 2005 | 03:40 AM
WaitinToDrag's Avatar
that happened to me a while back. Wierd thing is....the solenoid would only go out when I remote Started my truck. The installer tapped into some kinda wire that had something to do with the tranny solenoids.
Old Mar 18, 2005 | 06:11 AM
Stroker 1500's Avatar
well your problem is because you have to power on 2 ignition wires when you remote start it and most likely the installer only powered on 1 ignition wire
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
jtphelps289
Sep 1, 2015 08:58 PM
