418 build update pics and broke a ring
Old Jan 15, 2006 | 04:59 PM
  #181
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its definately hitting an 8 thousandths feeler gauge wont fit in between there
Old Jan 15, 2006 | 05:00 PM
  #182
They thought it was enough. Its either take more off the pistons or pull the crank back out and have them turn it down soem and rebalance it Im thinkin just drop the crank off in the morning and get them to turn it and balance it I hate doing the ******* rings on the pistons major PITA IMO. Mjhoward is at work and he wants to look at it so Im going to check all pistons and see how bad they are.
Call Eagle,they are listed in the Southaven MS phone directory and ask them how to address your problem.I'll bet they will have some answers.
Old Jan 15, 2006 | 05:11 PM
  #183
1slow01Z71's Avatar
Today=Sunday
Im just going to go ahead and get the crank cut down more than enough to clear it so I know for damn sure there aint going to be any more of these problems and get heavy metal added in and rebalanced and be done with it Im tired of doing this ****. One last time
Old Jan 15, 2006 | 05:47 PM
  #184
BLASTER's Avatar
Good luck tomorrow and cheer up man. It will be worth it in the end.
So, if you don't mind me asking, what was the price tag on this for the parts?
I heard 418 were tough becasue of the clearence issues. I like to dare to be different too but knowing that I built the motor is "different" enough for me. Your build has definately helped me learn some about the assemble and in my future plans
Good luck man.
Old Jan 15, 2006 | 06:05 PM
  #185
1slow01Z71's Avatar
It cost alot Ill just put it that way. If I would have had to buy everything new and didnt have hook ups on the price for everything it would have cost me close 8K for everything.
Old Jan 15, 2006 | 07:29 PM
  #186
JimS's Avatar
Be cool and polite.
Old Jan 15, 2006 | 07:48 PM
  #187
gomer's Avatar
11 Second Club
I would take the entire shortblock over to that machine shop and tell them that I didn't want the SOB back until it was right. You don't have the experience to make sure it is done correctly, and this isn't someting to "learn" on. Pay the money and make that machine shop responsible for it
When they get finished with it, you can just pick it up and install it.. that's the way it should be.
Old Jan 15, 2006 | 08:11 PM
  #188
1slow01Z71's Avatar
What is there to screw up if I tell them to cut 60 or 70 thousandths off? That will give me the clearance I need. Im not a complete moron. Mark will also be here to look and see if its right.
Old Jan 15, 2006 | 08:17 PM
  #189
Onyx 02's Avatar
Damn the luck bro! I hope everything works out well for you.
Old Jan 15, 2006 | 08:32 PM
  #190
TurboGibbs's Avatar
There were a few break downs in communication with this. First I was working and Cody dropped the stuff off. The machine shop claims Cody asked him to check the rod clearence to the block, Cody said otherwise but nevertheless there was a communication error. This shop, knowing I was involved probably assumed that I was taking care of all that as I had in the past. I have been working butt loads of OT so I wasn't able to check it out since Cody was in such a hurry. It would have envolved the block being bored and honed, picking the block up from the shop, dummying it up, and then carrying it back to get the balancing and clearencing done. Another 1-1.5 weeks. I wasn't that concerned about it because I thought all the rotating assembly came through Eagle and they had clearenced it. The custom milling on the counterweights would make most people believe the same. Come to find out the pistons never went through Eagle's hands. This is why I will never get envolved in something like this again unless I do all the parts ordering and homework. Cody simply didn't know any better to ask the questions that needed to be asked when ordering. Not his fault at all. We carried the short block back and the shop saw where it was hitting. It didn't look like it needed much and I agreed. He milled as much as he could off the pistons without shortening the skirts which are already about too short anyhow(the pistons only weigh 392 grams). Now they pretty much clear but just barely(less than .008") which isn't enough. .050 would be minimum in my opionion. The shop fixed the other for free and rebalanced. Now the best solution is to take turn the throws and rebalance with heavy metal. We could easily take just a tad off the skirts here in my shop on my milling machine and have the short block back together tonight. That would be so minimal it would not affect balance. Cody doesn't want to do that so it is his call and his money. The heavy metal balance will probably run him $200 more just for the crank.
I hope this clarrifies a little more exactly what the down falls have been and why. There isn't really anyone you can point the finger at. Like I said before, you can't build a one-off engine like this under time pressure. If there is a lesson to be learned from this for everyone on here, that is it.
