408 exhaust size
Old Mar 24, 2013 | 12:15 PM
DRAGGIN95's Avatar
Default 408 exhaust size
Hello, I have a Texas speed 408 coming, I will be using 317 head's and it is spec'd to be around 10.7-1 comp. ratio with those head's, TBSS intake, 90 mm DBC TB, TSP 228R 110 LSA cam, it will also have schoenfeld longtube conversion header's, the engine is going in my project truck, which is a bagged 95 chevy crew cab stepside. It's a big heavy truck and I want to keep all the low end torque and power that I can, I have read lot's of thread's about exhaust size but I am still unsure about whether to run 2.5 or 3 in pipes due to the size of the motor. I am planning on running dual's with an x pipe either way. I would like to hear you guy's opinion's on what size pipes you would run. Thank's
Old Mar 24, 2013 | 12:44 PM
ltr450ryder's Avatar
I run 3in duals only way I would do it on a 408
Old Mar 25, 2013 | 06:01 PM
DRAGGIN95's Avatar
Ok, thank's, anyone else have an opinion?
Old Mar 25, 2013 | 06:23 PM
03regcab sierra's Avatar
3" duals or at least a 3.5" single
Old Mar 25, 2013 | 06:33 PM
DRAGGIN95's Avatar
It will definitely be dual's, because of being bagged they run separately almost to the rear for ground clearance anyway, so I don't want to have to run them in to one single tailpipe.
Old Mar 25, 2013 | 07:50 PM
dirt track racer 81's Avatar
3" duals. I had some cone sound reducers in my 3" duals and when pulled them out I picked up over 40hp on the Dyno..
Old Mar 25, 2013 | 08:57 PM
DRAGGIN95's Avatar
Thank's guy's, this are exactly what I was needing to know.
Old Mar 29, 2013 | 03:54 PM
grm1738's Avatar
i ran dule 3" to a dule 3" in/out maganaflow x pipe to turn downs.. love it..
Stainless Works
13
Nov 5, 2015 03:31 PM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
