4.8L, what can it handle???
Old Nov 30, 2008 | 12:11 PM
Default 4.8L, what can it handle???
i picked up a LS7 cam and springs to hopefully put in the truck and on 1.8 rockers it has a .591 lift is what i read and
.558 with 1.7 rockers, can a 4.8 handle that or is it to much with the 1.8's, should i just use the stock 1.7 rockers? thanks.
-Kris
heres the specs:
Intake 211 deg. Exhaust 230 deg.
Lift .591 with 1.8 rocker and .558 with 1.7 rocker.
Old Nov 30, 2008 | 12:15 PM
00ChevyScott's Avatar
Wearin' da big hat
the ls7 is a 230/211, i think itd run like *** in a 4.8
Old Nov 30, 2008 | 12:26 PM
^ i wasnt sure thats why i asked before i put one in.
Old Nov 30, 2008 | 12:32 PM
dirt track racer 81's Avatar
with a 1.7 rocker it will be .558/.558
Old Nov 30, 2008 | 12:38 PM
alright but anymore opinions on how you think it will run with the ls7 cam? i dont want to put it in and be dissapointed.
Old Nov 30, 2008 | 01:26 PM
litreddevil's Avatar
Banned
do it already i got some 1.85 rockers for sale
Old Nov 30, 2008 | 04:09 PM
hog's Avatar
hog
the LS7 cam specs are:
211 degree intake / 230 degree exhaust
.591"/.591" Intake/ Exhaust
It'll run better than teh stock cam, butthis cam is designed for 7.0 liters that will make peak power at 6400 rpm in a 3100 lb Corvette..
Your 2.2L's short and at least 1000lbs heavier(at best) I'm sure there are better cams for your application.
peace
Hog
Old Nov 30, 2008 | 04:54 PM
i might just go ahead and put it in to see, but still thinking if i should get rockers or not?
oh and would it change the idle at all to lope more or anything?
Old Nov 30, 2008 | 09:54 PM
should i just wait to get the motor bored and heads milled? would that help?
