4.8l, what can it be built into?
Old Sep 6, 2008 | 07:50 PM
lo&sloSierra's Avatar
Default 4.8l, what can it be built into?
i have a 4.8l block and was curious as to if it could be built into something bigger?
Old Sep 6, 2008 | 07:59 PM
95 bright teal's Avatar
up to a 5.7 i believe
Old Sep 6, 2008 | 09:38 PM
sonoma43's Avatar
X2 I also believe it can be punched out to a 5.7, but not 100% someone will correct me if im wrong im sure.
Old Sep 6, 2008 | 09:57 PM
kbracing96's Avatar
Nope, you can built a 383 out of them,
Bore to 3.905" and 4" stroker crank
Old Sep 7, 2008 | 01:02 AM
didnt think about a stroker crank, but thats pushing the limit of the cylinder walls right?
Old Sep 7, 2008 | 04:06 AM
StrokerAce03's Avatar
4.8/5.3 blocks can be safely bored to 3.905. Its rumored that the blocks were originally designed to be turned into an iron 5.7 but they never did.
Old Sep 7, 2008 | 08:25 AM
silver-mod-o's Avatar
Hunt&Fisherator
Iron 383 would be the way to go... 5.3 and 4.8 blocks are identical.
Old Sep 7, 2008 | 08:37 AM
InchUp's Avatar
Sonic test first!
Make sure your machine shop sonic tests the block before machining anything. Not all blocks are perfectly identical. Case in point...my most current 5.7L build started with a 5.3L block and just with a stock LS1/6 99mm bore (3.898") my cylinder walls on #2 and #6 are at minimum wall thickness. On all the other bores I could have gone to 3.902-3.905" but since #2 and #6 did not allow it I was stuck with a stock bore, which is fine.
Also keep in mind that with the thinner walls, more heat will be transfered through the cylinder walls into the cooling system, so be 100% sure of your radiator size and efficiency with a fan.
Old Sep 7, 2008 | 08:39 AM
InchUp's Avatar
Only with high revs will you be pushing anything to it's limits, but the bored over 5.3L block can handle a 4" crank rather well. No machining necessary if you get the correct rods.
Old Sep 7, 2008 | 09:36 PM
ok well i have a 4.8 block, and im going the 383 route, so i need a 4" stroker crank and bore to 3.905, just having the machining done how much should i expect to pay?
