4.8l build questions
Old Dec 14, 2012 | 10:31 PM
blueboy02's Avatar
Default 4.8l build questions
well i ended up picking up a 4.8l a month ago with 30k on it and before tossing it in my truck i was looking to build it while its out. I'm wanting to do mainly the top end and a custom tune afterward. Any advice on what setup I should do, cam, heads, valves, etcs... Im not really wanting to turbo it either. so any help would be nice.
Old Dec 15, 2012 | 01:37 AM
53bowtie's Avatar
Budget? HP/tq goals? What type ofvehicle is it going in? We need to know some more info to help u out. What are u wanting to accomplish with the engine build?
Old Dec 15, 2012 | 10:07 AM
blueboy02's Avatar
well its a standard cab long bed 2000 sierra 1500 4.8l 5spd 4x4 lifted 6" on 36's. I have k&n cold air, BBK headers, High flow cats, Flowmaster 3", and a bully dog programmer. I did all those bolt ons to get more power which it helped alot. i blew out the 10bolt so i swapped in a 9.5" 14bolt SF w/ factory locker. my budget is around $1500 i want to put into the motor build and looking to get the highest HP for the buck, Id be really satisfied if I could get into the 400's.
Old Dec 15, 2012 | 06:54 PM
04Hall's Avatar
Its probably gonna require double the money to get to 400hp. A used set of performance Heads, Cam, Tune, convertor, and your already listed bolt ons will get you close or skip the cam and convertor and put a small shot on it.
Old Dec 15, 2012 | 08:30 PM
blueboy02's Avatar
well i have a 5 speed so no stall, but i planned on heads, cam, and tune. What would be the best head and cam setup is what I'm looking for. Cause I have a local guy that does an excellent dyno tune. And 400hp would make it sweet but 350hp would be nice
Old Dec 15, 2012 | 08:54 PM
04Hall's Avatar
Look on Texas speed site to the right, they have awesome head and cam packages. Bolt on right out of the box.
Old Dec 15, 2012 | 08:55 PM
04Hall's Avatar
212/218 is a awesome performing all around cam in these engines
Old Dec 15, 2012 | 08:57 PM
04Hall's Avatar
Give them a call and they'll spec out a set up that will best fit your needs and goals
Old Dec 15, 2012 | 09:18 PM
blueboy02's Avatar
thanks i will
Old Dec 15, 2012 | 11:05 PM
53bowtie's Avatar
You mean 400 at the crank I assume? You wont make 400 to the wheels with a 4.8 without boost, especially with 36" tires.
