4.8 silverado swap for 6.0
Old May 2, 2005 | 04:47 PM
  #31
Txboy89's Avatar
Originally Posted by GREGGO
It means a tranny that has been rebuilt with lot's of upgraded and stronger parts. Those usually run in the $2000+ range for a good build. Add a higher stall torque converter while your at it. You could upgrade to a stock 4l80 tranny with thwe adapter kit, but that will still run you close to 2k.
whats a higher stall torque converter? and whats 4|80 mean? thanks for your patience
Old May 2, 2005 | 04:59 PM
  #32
Ross @ EDO's Avatar
FormerVendor
When you have a higher stall converter, you can luanch to lets say 3000 rpm before it locks up and goes, wayy better 60' times. The 4l80e is the way stronger HD trannsmission.
Old May 2, 2005 | 05:46 PM
  #33
Txboy89's Avatar
so a new tranny is pretty much a must; and if later I decide to redo the rear end, what all does it need doing to it to keep up with the new found power? and how much does it usually cost?
Old May 2, 2005 | 09:23 PM
  #34
so if im reading this correct....you just swap the block, heads and intake and use everything else from you 5.3 or 4.8???? what about pcm or sensor's etc.????
Old May 2, 2005 | 09:26 PM
  #35
i belive you can switch over the intake also
you would want to leave the heads if you want stock spec compression
Old May 2, 2005 | 09:30 PM
  #36
99Silver6.0's Avatar
No no. The 6.0 317 heads flow too well to be putting the 4.8 or 5.3 heads on that motor!! The tranny will surely die after you put a 6.0 in. Also, instead of using the stock .052 gaskets you can use FelPro .041's instead. Bring the CR up a bit.
Old May 2, 2005 | 09:50 PM
  #37
budhayes3's Avatar
PT's Slowest Truck
Now, if you had a 5.3 with some long tubes, maybe ASM's or StainlessWorks or something...would you be able to re-use them with a 6.0 swap, or would you have to get new stuff?
Another question...didn't the early 6.0's have cast iron heads? which ones have the aluminum heads? Is there a motor ID sticky somewhere that I'm missing?
Old May 2, 2005 | 09:55 PM
  #38
so you just want the motor itself,block,heads,intake......no electronics or coils or any thing else?? then use evrything from the 4.8 or 5.3?
Old May 2, 2005 | 09:57 PM
  #39
You can still use all that stuff! Just stay away from 6.0's with cast iron heads. Try to find one thats 02+ and youll be ok. When you go look at one, check the head to see if it has 317 stamped on the corners. Those are what you want!
Old May 2, 2005 | 09:58 PM
  #40
You can do that!
