4.8 performance
Old Mar 8, 2006 | 03:49 PM
KY_BOB's Avatar
Originally Posted by Shock1420
What is a stall mod?
A torque converter with a higher than factory stall speed.
Old Mar 8, 2006 | 04:35 PM
ThunderZ28's Avatar
12 Second Club
Originally Posted by TigerFan187
Gears and tune should be first and then a stall.
agreed in that order..
sorry for putting them out of order...
I wasnt thinking straight
Old Mar 8, 2006 | 10:17 PM
05GMCL33's Avatar
Originally Posted by treyZ28
wtf? 4.8 in a 3500? my 4.8 was hunting for gears on the highway with any hint of hills
3/4 and 1 ton GM VAN'S come standard with the 4.8.
Old Mar 10, 2006 | 02:36 PM
OrlandoFL4.8's Avatar
Old Mar 10, 2006 | 03:36 PM
allenmehrer's Avatar
alright, shed some light on this... a torque converter is nothing but a hydrodynamic coupling between your crank and tranny. when both crank and tranny are running the same speed most of our trucks lock the converter to prevent slippage. so how then does do torque converters make 'more' power. i can see it helping launches for the 1/4 mile because you can increase your stall but thats it...
Old Mar 10, 2006 | 04:56 PM
treyZ28's Avatar
You do get torque multip when its slipping
conservation of energy applied over time (power) says
velocity*force(in) - losses = velocity*force(out)
When its slipping, the velocity(rpm) on one side (trans side) is lower so the force (torque) is higher. Think of gears, using velocity (rpm) to make more torque. However, power is still the same.
Old Mar 10, 2006 | 08:39 PM
reveille5's Avatar
Default mods
Shouldn't the tune be last after the stall.
Old Mar 11, 2006 | 11:15 PM
One_Slow4.8's Avatar
what kind of gears... rearend? what kind are recomended?? (not meaning to hijack)
Old Mar 12, 2006 | 08:18 AM
ThunderZ28's Avatar
12 Second Club
tune and stall, should really be done at the same time..
especially if you go with a high stall..
Old Mar 12, 2006 | 12:56 PM
onebadrubi's Avatar
for a 4.8 rcsb i would deffinately say 4.10's. Maybe on a tahoe a 4.56? THat might be to much gear but that would deff get him rolling good. 4.56 and like a 31" tire shouldnt be bad
