4.8 LY2 bigger injectors?
Old 11-05-2013, 01:08 AM
dbizzle's Avatar
Default 4.8 LY2 bigger injectors?
Been searching the interwebz for a while trying to find options for larger injectors for the 4.8.
Will be running e85 aiming for 1000hp, so what I've found is that they will need to be larger than 80's.
What are some good injectors for a decent price? Should I stay with the stock fuel rails or get different ones?
Old 11-05-2013, 01:51 AM
gamble686's Avatar
1000hp on E85? I would say you will be pushing the limits on the stock fuel rails. Are you planning on doing this in a 4.8? I hope you plan on a huge fuel system? Swap to returnless, and run big lines and fittings with a huge pump. Basically everything needs to be upgraded. As for injectors I would venture to guess these should cover it....
FUEL INJECTOR CONNECTION - F IC1000 95lb LS3 LS7 LS9 Fuel Injector set
103lbs should be close, but with e85 it may need more. If you need to go bigger you will be looking around $1000.
Old 11-05-2013, 02:00 AM
dbizzle's Avatar
yes, bigger fuel pump, surge tank, bigger lines, I know what I'm doing for those, I'm just stuck at what to get for the rails and injectors and which ones actually fit.
Old 11-05-2013, 02:28 AM
gamble686's Avatar
LS1 LS6 8AN High Flow Black Fuel Rails w Fittings Nylon Hose Hardware | eBay
Will you be running meth? That will reduce your injector issue.
Old 11-05-2013, 04:06 AM
dbizzle's Avatar
I will be running meth as well
Old 11-06-2013, 10:36 AM
dbizzle's Avatar
bump for more help
Old 11-06-2013, 11:25 AM
cosb's Avatar
What are you planning on doing to a 4.8 to make 1000hp? Good luck
Old 11-06-2013, 08:23 PM
dbizzle's Avatar
22-25lbs of boost and possibly some nitrous to get it there...
Will be getting forged pistons and rods before I turn it up that far even though I've seen some make 800-900 on stock bottom ends
Old 11-06-2013, 11:30 PM
gamble686's Avatar
Those injectors I posted should work fine to get you 1000hp if you are spraying meth as long as you are running 4bar pressure or more and your fuel system is all good.
DrX
01-23-2016 09:49 PM
RONIN LSX
08-11-2015 12:03 AM
03regcab sierra
20
08-03-2015 12:11 AM
Sexyrado327
08-02-2015 04:08 PM
MS3Z
07-30-2015 06:17 PM
Quick Reply: 4.8 LY2 bigger injectors?
