4.8 block ?s
Old Oct 31, 2008 | 07:13 PM
lo&sloSierra's Avatar
Default 4.8 block ?s
got a 4.8 block from work today for next to nothing, i plan on putting it in a s10, its a seasoned block so how much should i have my machine shop bore it out safely? normally with other things i go thirty over but that seems a bit too much for this, im scared to go to much because of how thin the cylinder walls are.
Old Oct 31, 2008 | 07:29 PM
i'm pretty sure you can go that much over safely. what exactly do you plan on doing with it is the question.
Old Oct 31, 2008 | 08:10 PM
GMCtrk's Avatar
You can go to 3.898
Old Oct 31, 2008 | 11:25 PM
Originally Posted by GMCtrk
You can go to 3.898
thats ls1 spec isnt it? and i dont plan to make it a all out race motor but i do plan to make it strong and drivealbe for the street, if i go thirty over on it, should i go ahead and go with a ls1 crank or see about having the one in it machined a bit? either though i dont want it to be an all out race motor i want it to be stronger than the average 5.3
Old Oct 31, 2008 | 11:52 PM
00ChevyScott's Avatar
Wearin' da big hat
make an iron block ls1.
Old Nov 1, 2008 | 01:11 AM
QLF's Avatar
QLF
The 4.8 shares the same block as a 5.3 and 6.0 IIRC. Just make it an iron block ls1 like Taco guy said.
Old Nov 1, 2008 | 01:32 AM
95 bright teal's Avatar
HAHAHA
6.0 block is different. 5.3 and 4.8 are the same. bore it out to a iron 5.7
Old Nov 1, 2008 | 10:03 AM
QLF's Avatar
QLF
Originally Posted by 95 bright teal
HAHAHA
Got it coach, I couldn't remember if the 6.0 was different or not. Thanks for clearing that up.
Old Nov 1, 2008 | 01:33 PM
No problem!
and i was laughing at the taco guy comment, if you were wondering...
Old Nov 1, 2008 | 01:35 PM
Wearin' da big hat
i wish it was the same as the 6.0 block
