4.8-5.7
Old Feb 21, 2006 | 09:34 AM
EvilChevy's Avatar
Default 4.8-5.7
Alright guys. I have a 4.8 block.5.3 crank and rods, and i am thinking of going to the machieneist for some creative boreing. I am also considering use of LS6 heads on this setup. I need any advice to complete this setup and produce the most horsepower. I am going to use an Thunder racing tr224 cam. Comp Lifters,comp roller rockers. Comp,valvesprings.
Old Feb 21, 2006 | 02:39 PM
912jonathon's Avatar
you will need pistons for a 5.7 if you want a 5.7. they are not the same as the 5.3. im doing the same thing, im using stock 5.7 pistons and rods. im also using the same cam but i got a set of stock 5.7 heads and im going to port and polish mine and have them shaved to 11.1 comp. you will need to bore the block 3.898 for the stock 5.7 piston. this is as big as you can go with that block
Old Feb 21, 2006 | 07:15 PM
Keith's Avatar
Pretty sure you can go to 3.905 on the 4.8/5.3 blocks.
Better be safe and sonic test it first though.
Old Feb 21, 2006 | 08:03 PM
EvilChevy's Avatar
According to my machieneist it'll be ok. I kinda got the Idea From Hot rod so i'm testing one of their theories.. Would the LS6 heads help or hur this stetup????
Old Feb 21, 2006 | 08:04 PM
Tractionless's Avatar
Someone here did a 383 with a 5.3 block so I dont see why a 346 would be a problem. You just need to get the pistons and rods from an LS1 or LS6. With the LS6 head, you would have a comp ratio of 10.5:1. sweeeeet
Old Feb 21, 2006 | 08:22 PM
EvilChevy's Avatar
Hell yes Now to get those Pistons and Rods form a LS6.. Just makes me wonder what the 1/4 mile times an hp numbers will be
Old Feb 21, 2006 | 08:31 PM
TurboGibbs's Avatar
5.3 & 6.0 rods are the same.
