4.8 5.3 Idle Fluctuation - Hi Pedal Effort 1999 to 2002
Old Aug 25, 2003 | 09:36 AM
Default 4.8 5.3 Idle Fluctuation - Hi Pedal Effort 1999 to 2002
I ran across this in the June 2003 issue in Motor - supposed cure for Idle fluc and an unstable idle - There is a air bypass plug for the thottle plate - 2 plugs are avail - yellow and red
1/8" = yellow
red is for holes smaller than 1/8" -
Check the holes with a drill bit.
Part 12580749 = yellow
Part 12581011 = red
Old Aug 25, 2003 | 02:54 PM
GREGGO's Avatar
Default Re: 4.8 5.3 Idle Fluctuation - Hi Pedal Effort 1999 to 2002
nice little tidbit of info. Thanks. BTW, those are GM part #'s.
Old Aug 25, 2003 | 03:53 PM
yes Greg those are GM part number - Motor is a good mag to get for underhood "tech" service bullentins etc...
FYI the mag is free
Just give yourself a business name
Old Aug 25, 2003 | 04:02 PM
onyx's Avatar
14 Second Truck Club
i'm guessing the throttle plate is located near the throttle body..
Old Aug 26, 2003 | 09:53 AM
GREGGO's Avatar
Yea, that's the blade IN the TB.
Old Aug 26, 2003 | 10:12 AM
onyx's Avatar
oh.... =X
Old Aug 26, 2003 | 05:47 PM
luckydf's Avatar
i have a 2002 Sierra w/5.3L it has a 9/64" hole. It has a jagged idle which the dealer says is perfectly normal. I don't get it. Since i am bigger than the 1/8" hole specified i guess it doesn't include me? Any other ideas?
Old Aug 26, 2003 | 11:59 PM
So what does this do, change the size of the little hole in the TB plate? Is that the idle hole or something? What will this do, give the engine a little less air? How do you know which one to get and what's to prevent it from falling out and getting sucked intot he engine?
Jim
Old Sep 2, 2003 | 11:46 AM
luckdf - according to the SIB - you would need the bigger plug -
Old Sep 2, 2003 | 11:48 AM
Y2k - it is a plastic rivet - it plug the hole - stablizing the idle according to the SIB - You put it in pull it thru and snip off the excess - help this helps
Oobray
Jun 13, 2022 03:38 AM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
GreyChevy
Jul 7, 2015 08:57 PM
