4.8-5.3 external difference?
Old Jan 29, 2006 | 05:18 PM
blazerboy72's Avatar
Default 4.8-5.3 external difference?
I know this has been disecussed but I couldn't find it using search. Is there any way to tell a 4.8 from a 5.3? I am picking up the motor for 71 Blazer tuesday and want to make sure i get the motor I paid for.
Old Jan 29, 2006 | 06:41 PM
TarheelZ's Avatar
Far as I know, the only 2 ways to be SURE would be if you had the correct VIN from the donor truck, or maybe take a spark plug out and try to turn the crank until a piston top is at TDC...maybe you can tell if it's a flat-top (4.8) or domed (5.3) piston.
Old Jan 29, 2006 | 07:40 PM
Onyx 02's Avatar
What TarheelZ said makes a lot of sense. The only other way to know would to have the heads pulled off to verify what shape of pistons it has.
Old Jan 29, 2006 | 09:01 PM
ktmrider's Avatar
Yep, what they said.
Another way is to pull the pan and check the part number of the crank, I think the 5.3L ( and all other GenIII motors ) ends in 215. The pistons are the best bet IMHO.
Old Jan 29, 2006 | 09:34 PM
white1's Avatar
No external differences, Good luck with the piston thing. Bring a flashlight with you, I dont know how good you can see into the spark plug hole, but I doubt you will be able to see all the way to th ecly wall to see ig its flat top, or dished. Let me know, cause I may be looking for another 6l, and thats the diff between the LQ4, and LQ9
Old Jan 30, 2006 | 03:51 AM
thanks I guess I will have to take their word for it.
Old Jan 30, 2006 | 10:43 AM
virgils4.85spd's Avatar
Default use small wire
Use a small wire and stick in the spark plug hole and see ifyou can feel the rim on the piston. It should have a small "wall". Just dont get too rough with it.
Derek
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
