4.8=13s?
Old Sep 5, 2006 | 09:57 PM
FILE's Avatar
I consider stall a bolt on... So a 4.8 with all bolt ons including a 3200+ stall should be in the 13's easily.
Old Sep 5, 2006 | 10:10 PM
dirt track racer 81's Avatar
just add a 100 shot and youll get there..nitrous isnt that bad and its a bolt on
Old Sep 5, 2006 | 10:18 PM
Derek @ EDO's Avatar
FormerVendor
Sure you can, all you need is a throttle body spacer, they give you like a kazillion hp/tq!
I would recomend a good stall/ gear combo this should be determined by tire height etc.
Also a great tune, dyno or Nelson IMO
longtube headers
And full boltons, every little bit helps, Like e-fans, pulleys etc.
Please note that 13's can be alot $cheaper with the 6.0swap
with that swap and a tune your there!
Old Sep 6, 2006 | 08:12 AM
Cuerva's Avatar
11 Second Truck Club
Originally Posted by UBLUZIN03
Can a bolt on only (no cam) RCSB run a 13?
Yes it can....I've seen 5.3's hit from a 13.4 to 13.6 with boltons. No reason why a 4.8 shouldn't dip into the 13's..
Old Sep 6, 2006 | 04:22 PM
UBLUZIN03's Avatar
I think it possible..im going to the track tonight to get some basline #...
Old Sep 6, 2006 | 10:06 PM
SierraSport's Avatar
Stock: 15.81 @ 90mph
I ran a 15.5@90.5 with a Muffler & stock intake modified/ those mods + 125 shot I ran a 14.3 @ 98mph.. Now I have gear, tune, posi, Intake , and throttle body spacer ..
My best time is 15.5 @ 92.1 and that was without gear, posi, and tune..
Old Sep 6, 2006 | 10:35 PM
get some 4.10's youll be hittin your self in the head for not gettin them sooner..also get the ''Tordnado'' another of this BIG power mods
Old Sep 6, 2006 | 11:01 PM
RabidStreetRacer's Avatar
a N/A (nitrous assisted) 4.8 can easily do it
Old Sep 7, 2006 | 02:42 PM
UBLUZIN03's Avatar
I dont want to put 4.10s in it because i have to drive 50+ miles to school everyday and i need the gas millage.
I went 16.066@86.69 my 60ft was 2.5 (no spinning)
I need a way better 60ft.....
Old Sep 7, 2006 | 04:55 PM
StrokerAce03's Avatar
What gears do you have? I'm running 3.73's and IMO a 4.8 should have no higher gears than that because of its lack of torque. A good converter and lower gears should definitely help along with a good tune. The mileage difference isn't that bad with the lower gears; best I ever got was a little over 21 mpg. It'd a little less with the 4.10's but worth it in the long run.
