4.3 to 6.0 swap with 5 speed. Help!!!!!
I was surfing the forum when I found this post , and thought of your thread. If you don't match the flywheel to the appropriate crank, and maybe match the crank/flywheel with an appropriate dampener, you may run into issues balancing the rotating assembly that can cause drivetrain vibration if not done properly.
Thanks for the info. I have been told that this is a internally balanced engine, so I'm taking my flywheel to a speed shop and making sure it has a neutral balance. Right now I believe it has counterweight in it.
Originally Posted by kw05silverado
I'm not sure but i dont think the 6.0s come w/ manual trans. The good thing is i heard that manual to automatic is easier than automatic to manual.So u may have to get a slush box.
GrooveCityZ71
Aug 31, 2015 12:05 PM
