4.3 to 6.0 swap?
Old Mar 29, 2005 | 06:24 PM
jeremys's Avatar
Default 4.3 to 6.0 swap?
has this been done? it'd be a lot easier for me money-wise to get a v6 RCSB and if possible put a 6.0 and eventually a 4L80E in
what things would i need to do? apparently the terms '4.3' or 'v6' are too short to search for. and the only things i've learned from a previous thread are pcm, trans, engine, tcase (lets assume the truck is a v6), and wiring need to be changed.
any idea on lists of what needs to be changed and an estimated cost?
thanks a ton
Old Mar 29, 2005 | 06:32 PM
loud5.3's Avatar
thanks a ton
It would be much easier to start with the 4.8 since the 6.0 is a plug and play drop-in replacement. The 4L80E is not nearly as easy though, no matter what you start with.
Old Mar 29, 2005 | 06:38 PM
jeremys's Avatar
oh. that makes it another 4-5k more to get a 4.8
guess i should wait another year or so
Old Mar 29, 2005 | 09:26 PM
gonzo 6.2's Avatar
If you are looking at used like a 2003 truck,a 4.3 is a $850 deduct in the kelly blue book(wholesale book) while a 4.8 is a zero add and the 5.3 is a $400 add.Looking at new it will be a little bit more of a difference.Start with a v8 truck it will be cheaper in the long run even if you dont value your labor.I gather you are doing the work.
Old Mar 29, 2005 | 09:37 PM
user 108208932024's Avatar
Banned
The 4.8 will be better. I'm pretty sure I've read that the motor mounts aren't the same. Plus the 4.8 may cost alittle more but you can sell the engine and recover some of the cost of the 6.0. Good luck to you.
Old Mar 29, 2005 | 10:52 PM
jeremys's Avatar
thanks for the info. i think i'm going to get a local s10 v8 project and drive that for a while until i can afford a v8 rcsb, even though i want a fullsize
Old Mar 30, 2005 | 09:49 AM
onyxsilverado's Avatar
understand that the 4.3 and the 6.0 are based on totally different technology. you'd need new motor mounts, pcm, wiring harness, radiator, tranny...ect. see this attached link for info i've scrounged for swaps such as this.
http://forum.ls1truck.com/index.php?showtopic=3419
this is mainly for 4.3->4.8/5.3/5.7 swaps, so include everything you'd need to swap from a 4.8 to a 6.0 on top of what i've listed in this link. When swapping to the LS1, we also had to change out the fuel rail...the 4.3 is a return fuel system and the ls1 is a dead-head.
Honestly, its not a bad swap, unless you do the full ls1 swap i did, but it's not the "weekend stab" like a 4.8->6.0 would be.
Old Mar 30, 2005 | 11:03 AM
jeremys's Avatar
thanks for the info. maybe eventually turbo-ing a 4.8 or 5.3 would be just as good for me
so a 4.3->5.3 swap isn't all that bad?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
85SS/85GN
Aug 7, 2015 04:30 PM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
