4.3 to 6.0
Old Jan 19, 2008 | 02:47 PM
formerly 20032wdsilverado (8/29/2011)
Default 4.3 to 6.0
I have a 2003 silverado with a 4.3. i hate the damn thing, i am gonna swap to a 6.0 soon but not sure of what else to do.
First, lq4 or lq9, i do some towing and a lot of off road. which one would be better for my application.
Next, Cam...who and what.
Third, Forced induction, again, who and what.
Fourth, Trans, built 60e, 65e, or 80e?
And last, Gears, i currently have 3.42s with a g80, what would be the best gear brand and best LSD?
Thanks for everyones help.
Old Jan 19, 2008 | 07:00 PM
bump for the evening
Old Jan 19, 2008 | 07:24 PM
Wide Open's Avatar
There isn't a huge difference in the LQ4 and the LQ9, LQ9 has higher compression and therefore a bit more hp, if you are thinking of adding a cam and forced induction then definitely don't waste any extra money on getting an LQ9.
Most of the questions you ask or more personal opinion than anything else.
Old Jan 20, 2008 | 07:25 AM
i was just wondering who has had a good experience with what brands and are there any that i should stay away from
Old Jan 20, 2008 | 01:38 PM
Wide Open's Avatar
I wasn't trying to discourage you in any way; I was just trying to say most of the parts are created equal and it boils down to personal preference. Good luck with your project. Your truck is going to be a ton more fun with a 6.0 than it is with a 4.3. I went from a 4.8 to a 6.2 and I can't believe the difference.
Old Jan 20, 2008 | 02:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Like said, if you do plan on doing forced induction go with the lq4 do to lower comp. either way I don't think ou will be diss with either engine. Also the cam will have to be based on if your going to def run FI or keep it na, big lumpy cams usually don't like to work with a FI setup. Every thing else is preference. Do a search on 6.0 and you will come up with more info then you will care to read. Good luck.
John
Old Jan 20, 2008 | 03:11 PM
thanks guys
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
