4.3 to 5.3 swap
Old Oct 28, 2003 | 10:00 PM
RED2K's Avatar
If this is truely what you want to do then good luck. There will be alot of , how does the old saying go, alot of blood , sweat, and tears go in it. It would be easier to put in a nice strong 406 or 383 sbc into it i would think
Old Oct 28, 2003 | 10:48 PM
Banned
hey, i know a guy with a 383, and a 406 that he'd probably sell for the right price!!!!!
Old Oct 28, 2003 | 11:09 PM
benpimpin1's Avatar
how much? what all is needed, dont know much about them, compatible with my electrical?
Old Oct 28, 2003 | 11:43 PM
Banned
Alex....how much you want for'em???
Old Oct 29, 2003 | 09:39 AM
Beavis5.3's Avatar
Before you S-can the 4.3, maybe you should look at doing something with it. For the money you'd spend on getting everything you'd need for the 5.3L swap, you could probably do some killer stuff to the V-6.
I know this is gonna ruffle some feathers because V-6's are sorta the red-headed stepchildren of performance, but keep an open mind here.
Let's set the wayback machine for the early 90's. Anyone rememebr the Cyclone and Typhoon trucks GM put on the street? These were S-10's with a supercharged 4.3L V-6. They were killer pieces.
Now, fast forward back to your current situation. Superchargers for the 4.3L V-6 are plentiful from the various companies. So, why not do a cam and valvetrain upgrade to your V-6 (There is stuff out there!) Upgrade the injection system with some earlier V-8 parts, and bolt on a killer blower to it? Hell, maybe even a nitrous set-up for the occasional extra kick?
Look at all the power the import guys are making with V-6's, and the ones they have to work with don't have near the performance potential or ruggedness as a 4.3L Chevy V-6. A lot of the performance parts you could buy are just V-8 parts in the right quantities for the 4.3
In the old days, a V-6 to V-8 swap would have been the way to go, but with the complications you'd have, a performance upgrade with the 4.3 would be more cost effective.
Plus, think of how cool it will be to kick some guy's *** on the street, then pop the hood and show him you did it with two less cylinders!
Old Oct 29, 2003 | 10:04 AM
benpimpin1's Avatar
I considered that route before and it came down to if i raced someone with an 8 and they had the same mods they would woop me. I had an old f-100 before my silverado with an 300c.i. inline 6. I put an offenhauser intake on it with three 2 barrel weber carbs and a nice cam grind and it was pretty sweet, but still couldn't run with a 302 modded up. That was ok I liked being the underdog cause nobody new what the hell was in my effie (sounded pretty neatcause it was an inline) It was just as easy this time around to buy a motor and completely rebuild it how I want with no time factor cause im not pulling my motor out.
Old Oct 29, 2003 | 06:09 PM
RED2K's Avatar
I have a 406 and a 383 for sale. I have a 6.125 rod 355 for sale but the price on it will make you choke. It has over $7000.00 in it and doesnt even have a intake, oil pump, push rods, or dressed. The 383 has a LA billet { brooks racing componets} crank that is almost $2000 its self. The 406 is stock but with SRP pistons. It has the pink rods and a set of p&p double hump heads with 2.02 manley stainless steel valves. I will let it gor for $2500.
Old Oct 29, 2003 | 07:35 PM
hyper's Avatar
comon buddy... we're talkin about a fullsize truck here, not an import or s10 which weighs a ton less
Old Oct 29, 2003 | 08:13 PM
benpimpin1's Avatar
even if i put 2500 just into a older style motor then what else will i have to do, i got my 5.3 dirt cheap and will have $2500 into that after stage 2 heads and a cam. doesn't seem much cheaper if any.
Old Oct 31, 2003 | 09:34 AM
Beavis5.3's Avatar
True, but power to weight ratio is power to weight ratio, no matter what the vehicle.
Obviously a V-8 is preferred to a V-6, just trying to give an alternative that might not cost as much.
