4.3 to 5.3 swap
Old Oct 27, 2003 | 05:39 PM
benpimpin1's Avatar
Default 4.3 to 5.3 swap
Swapping my 4.3 liter 02' silverado for an 01' 5.3 liter anybody Know anything about what is needed for my wiring? has anybody done this swap? i dont have the full harness for the 5.3 liter, just the plugs and some clipped wiring. any thoughts?
Old Oct 27, 2003 | 05:41 PM
LS1Tech Sponsor
As far as I have seen everything is direct swap all the same stuff.
Nate
Old Oct 27, 2003 | 06:03 PM
L-EATER's Avatar
11 Second Truck Club
Yeah, I have thoughts. You ain't gonna get there without a harness. The 4.3 is a completely different motor sharing a lot with the old SBC but nothing with the LS1 based motors. You almost need a donor truck to get everything you'll be needing-fuel lines,etc.
Old Oct 27, 2003 | 06:10 PM
FILE's Avatar
If you are going throgh the trouble of doing the swap, just go the whole nine yards and go with the 6.0....
Old Oct 28, 2003 | 10:34 AM
LS1Tech Sponsor
The 4.8 is a LS* motor. It is identical to the 5.3 5.7 6.0 motors. It is the same block as the 5.3 just a differant crank.
Happy Motoring Nate
Old Oct 28, 2003 | 11:36 AM
Seeing Red Again's Avatar
Happy Motoring Nate
While that is true, he said 4.3 not 4.8.
In my opinion, that swap is waaaay more trouble than it's worth. Just trade your 4.3 truck for one with a 4.8/5.3. You can do the research if you want, but I'll bet by the time you price how much the swap would be including a new tranny/radiator/wiring harness/ecu, possibly drive shaft, etc, you could have covered the price difference for the truck trade. Plus if you trade you won't have all that time involved to get everything to mate.
Old Oct 28, 2003 | 12:04 PM
benpimpin1's Avatar
In the mean time I am going to build up my motor and research some more into it, I really dont want to get rid of my truck but if i must than i must. Maybe I can keep my ext.cab and get a wrecked single cab to dump the motor in and put an escalade front end on.
Old Oct 28, 2003 | 12:22 PM
marc_w's Avatar
The drivetrain is the same on the 4.3's, for what it's worth...
Old Oct 28, 2003 | 12:51 PM
benpimpin1's Avatar
during my motor build i am going to try and find a harness out of a wrecked one, hopefully i can get one, i dont think theres a whole lot different other than the harness, i think my accesories change over. have to have a harness mated with my old one for some things im sure, i will let you all know though
Old Oct 28, 2003 | 01:06 PM
Banned
your accessories such as alternator, ac and all that wont swap over, the fuel system is TOTALLY different between a 4.3 and 5.3 so like it was said above you'll need a donor for all that, or just build one from aftermarket parts but that could get expensive. not a direct swap in any way, and much more trouble than it's worth.
