4.10 vs. 3.73, general gear questions (long)
Old Oct 23, 2004 | 10:05 PM
Mr. Sandog's Avatar
Default 4.10 vs. 3.73, general gear questions (long)
Alright, I've received some advice that to get some more power (that I can feel, since I don't want to swap out the converter), I should consider 4.10 gears instead of my stock 3.73's. Problem is, I don't know anything about gears. I've done some searching and reading, but I've been coming up short in the knowledge arena. So I need some help.
One of the things I seem to read is that the actual 'gears' are different from the other stuff (G80 limited slip, Eaton posi, etc.). Is this the case? Is gear replacement different from a posi installation or replacement? Are these two different things? If so, does that mean I can replace my 3.73 gears with 4.10 gears, and leave the G80 part? What brands of gears are good?
The other thing I am concerned with is strength. I've heard that the stock G80 is weak....is that true? If so, do I need to put something else in when I do the gears? If so, what should go in there? I've also heard that a good aftermarket cover made out of stainless or aluminum will go a long way toward keep the rear end together. Is this true?
I've also heard that not just anyone can do gears, that it's a delicate operation and it can be screwed up pretty easily. Is this the case? If so, what should I watch out for when it comes to looking for a shop? There's ORW and 4 Wheel Parts around here, I'm wondering if they would be good places to check out.
Old Oct 23, 2004 | 10:10 PM
DUNGBEETLE's Avatar
Banned
Man I went from 3.42's to 4.10's in my silvreado 2003, I love them, IMO, Strange is the best gear made. I have absolutly no noise coming from my rear end, and there only about 190$ a set, and make sure you get the Deluxe installation kit that comes with the bearings, I made that mistake and paid almost 250$ just for the bearings and with the deluxe installatiion kit they come with all the parts and bearings for about 85$. STAY AWAY FROM RICHMOND, i have heard they make alot of noise. I paid 325$ for installation and it took about 6 hours. Times are 16.3@84 with headers and airintake, went to 4.10's and a computer tune(which you need for the gears to calibrate your speedo) dropped to time in my sig. Greatest investment for me so far. Gas mileage takes a little hit, but not enough to be noticed, i run 93octane with 4.10's and run about close to 400 miles a tank. Hope this helps
Old Oct 23, 2004 | 10:12 PM
DUNGBEETLE's Avatar
Banned
www.strangeengineering.net is the site where i got mine, if im correct i think if you have a 99 and up silverado, then you should have a 8.5 10bolt, dont quote me but I think thats what you have
DUNGBEETLE's Avatar
Banned
About looking at shops, i would look for a shop that has a history in dragracing
Old Oct 23, 2004 | 10:28 PM
MacADaYear's Avatar
Yea they are different. You can change out the posi, or change out the gears seperatly. You could leave the G80 and change the gears to 410s.
I think its a universal knowledge around here that the eaton posi is the way to go. I just got one and they run anywhere from 350-400.
T/A girdle and stud kit is about as good as they get I think. Do a search and im sure there will be plenty of info
Old Oct 23, 2004 | 11:05 PM
Mr. Sandog's Avatar
Grrr, Thunder has a nice 10% off sale through tomorrow (Sunday), but they only have Strange 4.10's for 7.5" rear ends, no 8.5 inchers!
Old Oct 23, 2004 | 11:10 PM
DUNGBEETLE's Avatar
Banned
you can get the strange 4.10's for like 180 from the website i posted above
Old Oct 23, 2004 | 11:16 PM
Mr. Sandog's Avatar
Alright, got it - thanks. Guess I'll place the order on Monday....
Old Oct 23, 2004 | 11:45 PM
moregrip's Avatar
what a rush!
I'm pretty sure the GM 10bolt is actually a 8.6" ring gear
http://www.aam.com/technology/tech_p...araxle860.html
Old Oct 24, 2004 | 01:13 AM
all good info for you here...except the richmond part...they're fine..the noise comes from a backlash tolerance the installer missed on...unless youre doin slicks & power over 500 at the wheel, that 10 bolt will be fine...the g80 is fine also...get the backing plate, and invest in a c-clip eliminator...i suppose 10-bolts still have c-clips, i run 9 inch in anything with power but i have a g80 in my RST and have seen many 10-bolts take severe abuse time after time
